Inspire Tail question
Ok im installing my inspires, but the OEM tails have an extra small light, and on the inspires, there is no hole for the small 4th light. If you have inspires, did you leave that light haging, or cut out a hole and jerry rig it?? what is the light for?? I checked and I got brake, blinker lights?? is it the parking light??
I just used electrical tape and taped it to the housing so it wouldnt rattle when i was driving. Dont waste your time drilling the hole in the back, just secure the light down, having the light in there really doesnt make much of a difference.
Inspire
I bore holes for the side marker lights and the plastic went all ove the place.
Keep it hanging, it will not do anything, or else tape it to the shroud, use good tape though, it will be a bit hot.
I guess your inspires tails didn't come with JDM wiring harness. When I bought mine, they came with the JDM wiring harness, I just swapped that with the OEM. Thus, I don't have the extra bulb hanging around. To avoid it being too hot, unplug the bulb, since you don't need to use it.
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
