Ignition Switch Install...
Old May 4, 2009 | 10:30 PM
5point9Limited's Avatar
My ignition switch is bad. I jumped the 2 wires with a T-tap to get her running temporarily. I will show pics. Does anyone have a writeup on this procedure? I have never done one before. I will take pics and do a detailed writeup. Thanks guys.
Old May 4, 2009 | 11:44 PM
tmnhs81's Avatar
you will need special tool like steering wheel puller and stuff. Its easy just need right tools.
Old May 5, 2009 | 12:06 AM
desired_speeds's Avatar
its not hard, just take off the two little gold screws behind the white cover, then pull the switch off and follow the harness that i think.. plugs into the fusebox. unplug and replace.
Old May 5, 2009 | 12:13 AM
tmnhs81's Avatar
^I did a few on GM cars. Had to pull steering wheel, airbag apart to get to the screws holding ignition switch, about Honda/Acura. Never had a chance.
Old May 5, 2009 | 05:32 AM
Thanks guys. I really hope I don have to pull the wheel. I am going to disco the battery since im working around the airbag. tmnhs, have you done one?
Old May 5, 2009 | 05:35 PM
ive done a few on legends, its a 20 minute job.
Old May 5, 2009 | 07:17 PM
Ok cool, thanks. Just unbolt, unclip and install?
MilanoRedDashR
Oct 8, 2015 10:30 AM
malvothegreat
Sep 29, 2015 12:38 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
h22lude
Sep 27, 2015 06:22 PM
eastcoastguy
Sep 23, 2015 06:29 AM
