Ignition Problem
Old Oct 1, 2003 | 08:37 PM
d3rk's Avatar
Become Hypnotized
Ignition Problem
I have a 98 Acura 3.2TL with right at 100,000 miles....Well If I let my car sit for a while i'll turn the key and all I get is a click, if i give it like a minute and try again it'll crank rite up, but i can try it like one to 30 times within that minute and it still won't crank but like after a minute after the intial turn it'll crank right up....if anyone has had this problem or know how to fix it plz right back...thanks
Derek
Old Oct 1, 2003 | 09:45 PM
i had a problem similar to that a yr back, took it to the dealer, they just replaced the starter
Old Oct 1, 2003 | 09:56 PM
tlfan96's Avatar
Sounds like you have a flat spot in your starter. Had the same problem, until one day i cranked the car and a loud scrapping noise came from the engine and the car was trying to crank itself. I took the key out and the car would not stop trying to crank, finally the starter started smoking and burnt my battery terminals. Had to replace starter and battery.
Old Oct 2, 2003 | 12:08 AM
d3rk's Avatar
Become Hypnotized
how much does it run to have the starter replaced.
Old Oct 2, 2003 | 09:25 AM
It might also be ur ignition switch i recently had to replace mine fro like 350 but since urs a 98 its covered under a recall and it will be free get it check out
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Juandiablo
Sep 27, 2015 10:32 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
