I get stranded on the road sometimes
So my Tl leaves me stranded for a little while every now and then lol. I believe it may be a common problem and any help given will be appreciated. The car wont crank up or start when i turn the key. The the dashboard will be lit and so will the radio and or anything else but the engine does not even hesitate to crank. I will have to just wait until when the car wants to start and then it will. Anyone know why?
It could be keyswitch. Check blk/yellow wire at distributor or COP for power when keyswitch is ON. If no power, the keyswitch is bad.
It could also be main fuel relay. Listen carefully when you turn keyswitch to ON. You should hear main fuel relay click under the dash and fuel pump whirring softly in fuel tank for 2-3 secs and stop. If no relay or fuel pump sound, the main fuel relay is very likely.
good luck
good luck
good luck
good luck
thanks eveyone for the helpful tips
I can feel your problem bro. My sisters civic is doing this alot, still trying to figure out what the hell is wrong with it.
It loses power all of sudden, no matter what you do. won't start for another 2-3 hours(sometimes sits overnight.) It doesn't gives any codes. It cranks so battery is fine, starter is fine. so I fuckin hate when this happens.
car runs fine most of the time. no problem at all. Is it suppose to do that.??
Thanks for ur reply TexasHonda. Any more suggestions will be helpfull.
It might be worth a try to remove upper timing belt cover, spray the sensor w/ engine cleaner and blow dry w/ compressed air. Dirt/oil/grease accumulation can degrade the signal output and cause an error. Not sure the sensor is accessible by removing upper timing cover, but worth checking.
good luck
good luck
Tmnhs81: I'm replying to Kev16, and suggest starting your own thread for help. It's difficult to sort out responses for two problems at same time.
Kev16. What TL are we discussing 2.5TL or 3.2TL. They have different ignition systems.
good luck
good luck
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
