How do you clean the EGR valve?
Hello folks.
Can someone tell me how to clean the freaking EGR valve?
I used the odbCII scanner and its said its the egr.
I had it cleaned by the dealer last year this time.
Now I get this again. I may as well do it myself.
Thanks.
Thanks.
What code was presented? Some codes indicate EGR valve or EGR manifold blockage, others indicate faulty vacuum control solenoid, or other problems.
EGR valve is difficult to clean, but generally does not get blocked. You can test the EGR valve by applying vacuum w/ hand pump or orally to lift the valve pintle w/ engine at idle. Engine will die as EG leans the mixture, if valve is opening. If no change in engine, the valve may be blocked. You can sometimes clean w/ throttle body cleaner and a wire, but access is very difficult.
Most frequent problem w/ EGR system is blockage of the manifold and ports that distribute the EG into the intake manifold.
Working on your car w/o a manual can be expensive, when you replace parts that are working fine.
good luck
good luck
All about JDM
What year is your 2.5? if its a 96 or 97 it should be covered under the extended emissions warranty till 140k miles. that egr and other shit should get fixed for free. my bro has a 97 and blows 02 sensors all the time and his egr valve replaced like once a year it seems. all for free. look into the warranty thing.
TL Enthusiast
any problems like this on the 9.8 2.5 TL? hopefully not. i haven't looked into recalls or anything like that. let me know. thanks.
