high offset wheels for 3.2's
'96 3.2 TL
Does anyone have high offset wheels on their 3.2? (+48, + 50 or above) If so, can you post some pics, please. Its very hard to find these high offset wheels. Does anyone know where to find them? (Tire rack and discounttiredirect, etc have a real slim lineup.) Any pics or input is appreciated.
thanks, Andy
thanks, Andy
The 3.2 has a larger wheelbase than the 2.5 and needs greater offset rims otherwise the wheelbase will extend even further and cause tires to rub with the car's fenders. That is, unless you stiffen the suspension.
I tried +40 offset 17" wheels on my 3.2 and the rear wheels rubbed when I carried rear weight and took curves or heavy bumps. For comparison, the stock 3.2 wheels have +65 offset.
All about JDM
1998 3.2TL
Originally Posted by 982.5TL
I have 17x7 +42 and have no rubbing issues. Mike has 18x7.5 +42 and has no rubbing issues either.
Stock wheels have a +55 offset. If you want high offset get 3 piece wheels for custom offsets. I have 17x7 +42 and have no rubbing issues. Mike has 18x7.5 +42 and has no rubbing issues either. I think 7.5 +42 is the lowest offest to avoid rubbing on the outside. I guess depending on the tire you can get away with a 7.5 +40 at least on 2.5s, is that what you have Baller or do you have 7 inch wide wheels. I dont know about 3.2 clearance. Getting a higher offset like +45 or +48 or higher as you get wider should save you from rubbing.
'96 3.2 TL
most of the response so far is from 2.5 owners. The 3.2 has a lot fewer options of wheels that will not rub. I have 17 x 7s with a +45 offset on the car right now. The appearance is that they stick out a little bit. They also rub with the car fully loaded.
I plan to move up to 18 x 7.5's and put on some eibach springs. I don't want to be rubbing on bumps. The absolute lowest offset I'm going to consider is +48, but I would like to find some +51's or higher. I'm looking for info on wheels with this type of offset (where to find them or any info from people who have used them or pics).
Thanks for the help, guys.
Andy
Andy
I have 18x7.5 +48 off set PIAA super rozzas with 225/40 18 tires and no rubbing issues. But I also have the eibach prokit and my fenders shaved. You can see pics on the UPDATED PICS thread here.
All about JDM
Originally Posted by Petie
Do you or mike have a drop at all? If so, with what and how much?
the back of my rim says 15 - 6 1/2 - 65
nuldabz
09-03-2015 05:49 PM
