high HC ppm
high HC ppm
Hi, I just had my emission inspection,
my HC ppm at 40km/hr is at 53 (55 is the limit)
at idle its 21 (200 is the limit)
2 years ago it was 6 and 7 respectively.
what could be causing this? I passed emission but I dont want to fail the next one or have bad gas mileage.
Any ideas?
Thanks in advance
Any ideas?
Thanks in advance
Here are the numbers
=== CURB IDLE ===
HC ppm: 21 (limit 200)
CO%: 0 (limit 1)
NO ppm: N/A
RPM: 640
Dilution 14.60
=== 40 km/h ===
HC ppm: 53 (limit 55)
CO%: 0.06 (limit 0.31)
NO ppm: 46 (limit 0408)
RPM: 1623
Dilution 14.66
The car otherwise is running fine. No rough idle. The only thing I notice is sometimes a rougher shift from gear 1-2 (or 2-3?). I did a drain and fill of my transmission fluid with OEM honda fluid but didn't notice significant improvement..
What are symptoms of misfiring?
Thanks.
=== CURB IDLE ===
CO%: 0 (limit 1)
NO ppm: N/A
RPM: 640
Dilution 14.60
=== 40 km/h ===
RPM: 1623
Dilution 14.66
Thanks.
Carefully inspect PCV valve and hoses (intake and delivery). A blocked PCV or PCV hose can force excess oil into the engine through the PCV air intake (reverse flow). This would also cause excess HC.
good luck
good luck
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
