Hi Po brake pads, rotors, fuel regulators
Attorney- Will Sue 4 Food
Trying to find stuff for my 3.2, came cross these:
AEM Fuel Pressure Regulator
http://www.kingmotorsports.com/categ...ategory=Engine
Hi performance pads & drilled rotors, power slot rotors
http://www.kingmotorsports.com/categ...ategory=Brakes
Re: Hi Po brake pads, rotors, fuel regulators
You having fuel delivery issues?
Do you have a Super Charger?
More fuel doesn't always mean more HP :-)
If it's not a good mix, it could be worse.
Are you looking at this one?<i>Power Slot Rotors
In-house manufacturing, plus the highest quality blanks assure precise inventory management and quality control. The exclusive Power Slot "tapered slot" design has clearly replaced crack-prone cross-drilled rotors in popularity. Power Slot rotors have bright, corrosion-resistant plating, plus the performance and strength of a slotted rotor. </i>
It says "In-house manufacturing" ... "highest quality blanks"
This means they Drilled it In Their House/Garage/Office :-)
I wouldn't buy these unless I know for sure they were Balanced AFTER they were Drilled.
If they did not balance it after the drill then ... it's more trouble than they are worth.
Take Care,
M
lanechanger
10-13-2015 10:56 AM
xsilverhawkx
09-28-2015 06:51 PM
