Help My Fog Lights Arent Working!!!!
okay well my foglights have been dead (so i thought) for couple months now and i never bothered changing them cause i was never a fan of the yellow condom....but i discovered on this site how to take them out about 2 months ago and just 10 minutes ago is when i decided to get my lazy arse up to take them out and change the lights....well turn outs my lights ARENT blown....the little coil is still intact and looking good...yet they dont turn on...this is for BOTH fogs...so i tried checking the fuses.....it wasnt that either....WHAT THE HELL IS IT?????? i noticed the connectors for the lights were disgusting....had what looked like crap on the bottom of a shoe but in the socket....could it be that? could it be my wires are bad? what is it? please any info would be appreciated
If fuse 36 in the underhood fuse box is good, and you see the indicator light on at the fog light switch assembly in the dash, the bulbs are bad, or bad plug connection, or bad ground connection. If both lights are off, the more likely scenario is bulbs are bad despite your visual inspection. Only way to tell for sure is w/ a VOM.
If indicator light in the dash is OFF, the fog light relay is bad, or the dash fog light switch is bad.
good luck
good luck
Originally Posted by steadyACridin
theres a dash switch for the fog lights? i thought they just turned on when i turn on my headlights????? i have a 1996 2.5 if it makes a difference
Registered Driver
Originally Posted by ljmushock
The fog switch should be right next to your cruise control on the dash behind and to the drivers left of the steering wheel... look for it, it will have what looks like a fog lamp on it... when u push it on the fogs should come on, and yes they only come on with the headlights unless you have spliced the wires for them to come on with the running lights... good luck!
thanks a lot guys.....see i had no clue that was there cause i dont have a reason to put my fingers back there being as i never use cruise control....i was pretty close to taking it to acura to tell me what the hell was wrong.....lol wow i feel like a moron....thanks again for all of your inputs.....anyone want a pair of yellow condoms?
p.s. what do you mean wired to running? i know they dont work when i switch my highbeams on
Registered Driver
I have mine setup with my carputer so that they turn on when I turn the car on, off when I turn the car off. I saw a suggestions for which wires to splice on the forums here before, but you had to make sure to turn them off.
When I get my car back, I'll take a peek and let you know which wire is the one going to the fog lights.
no dont dont worry about about ill just always leave the button on now so when i turn my headlights on they go on.....i already had silverstars in my headlights and im getting another free pair from my friend at advanced for my fogs when i take the condom off today....once again is anyone interested in these?
if you dont want to spend time troubleshotting, just re-run some wires with a relay and fused. Thats what I did to mine. now mine can do day time running lights or without the need to turn on the main light. goodluck.
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
