help: installing new water pump
any 1 have a write up for DIY? i am stuck! can some 1 help me plz!
so far i removed the intake and the throttle thing for clearance. what should be my next step? seem to me like i need to remove all the belts ETC to get to the water pump. if some 1 have done it and live in Chicago land. im willing to give some cash to help me out. let me know! thanks
Is this a 3.2TL or 2.5TL?
For both, the water pump is driven by timing belt and is usually replaced w/ timing belt work. If you aren't comfortable w/ timing belt replacement, you best bet is to call a tow truck and tow to a shop for help.
How do you know water pump is leaking?
good luck
good luck
remove the battery, intake rubber hose, plastic wire harness cover, unplug everything in the way and fold the wiring harness over the top of the engine. Remove the top radiator hose if you need more clearance. remove all belts, crank pulley, a/c tensioner, dipstick tube, then start removing all the timing covers. YOu can now remove the timing belt tensioner and timing belt. After that remove the drivers side cam gear and the backing plate behind it (3 10mm bolts) Now you can remove the waterpump.
Khmer Pride
i just got mine done for 120.00 with 6 can of beer and a pack of cig .everything was replace including thermosat..
mugen_kid
11-13-2015 10:38 PM
asahrts
09-04-2015 05:55 PM
