Help!!
Old Mar 15, 2008 | 02:24 PM
96acura2.5tl's Avatar
Help!!
there was smoke coming out of my engine, the temperature meter jumped to H and when i looked at the engine there was greenish fluid on the passenger side of the engine. so if u were standing infron of the car itll b to your left. any idea what happened? that stuff isnt oil leaking is it? i didnt have time to take it to the garage yet prob monday, so is it ok to drive the or not?
thanks
Old Mar 15, 2008 | 03:44 PM
TRIP_rock's Avatar
That green stuff is antifreeze from the cooling system. I wouldnt drive it until you get it fixed unless you want to take the risk of overheating the engine and causing more damage.
Old Mar 15, 2008 | 05:54 PM
HighMileage2.5's Avatar
Hopefully it's as simple as replacing some worn tubing. But definitely don't drive it until you aren't leaking serious amounts of antifreeze
Old Mar 16, 2008 | 02:30 PM
so i put in some antifreeze but now the engine temp isnt going to the middle, its staying closer to C.
Old Mar 16, 2008 | 03:03 PM
main70072's Avatar
Keep an eye on it to see if there's anymore antifreeze coming out of anywhere. You might have a small radiator crack like i did months ago or your radiator hose has a cut in it somewhere. Get it check ASAP.
Old Mar 18, 2008 | 11:49 AM
so its a bad radiator, its going to be $400. is that resonable?
Old Mar 18, 2008 | 11:58 AM
meazz1's Avatar
an after market rad will run about $140.00 to $175.00.
If you let a shop install it, it should not be more than $100.00
Old Mar 18, 2008 | 12:14 PM
really? its a new on ,its coming from another city. and yea the shop is installing it. is $400 still too much?
Old Mar 18, 2008 | 12:44 PM
and i checked @ 3 diffrent places and its all around $400
Old Mar 18, 2008 | 04:50 PM
KrayzieDxC's Avatar
Khmer Pride
yea $400.00 w/install and radiator
Old Mar 18, 2008 | 10:54 PM
main70072's Avatar
a decent aftermarket radiator should not cost more than $200. installing it on our car is not that difficult either as i have done mines myself. installation should not cost that much...
Old Mar 19, 2008 | 12:35 AM
Ken1997TL's Avatar
$300 at most
Old Mar 19, 2008 | 01:35 AM
Go90go's Avatar
大日本帝国
$140 cost for me for a brand new one, I installed it myself in a total of 20 minutes including water fill. Unlike someone else on the boards who paid $150 for it to be installed...
~Cheers~
