Heating / Cooling Issue
Old Apr 20, 2004 | 08:19 AM
Exclamation Heating / Cooling Issue
Hi,
Two months ago I had my thermostat replaced because I wasn't getting any warm air through the air vents, though the engine was hot. In fact the engine was almost to the point of over heating, the temperature back in January was very very cold outside. The new thermostat seemed to do the job, engine was cooling itself properly and heat was now coming into the cabin. Since last Friday my engine has now starting getting to the point of almost overheating and warm air seems to take longer than usual to come through the air vents.
Has anyone had a similar experience? How can I resolve this issue? I find it hard to believe the thermostat is gone again.
Thanks,
William
Old Apr 20, 2004 | 11:38 AM
=]Shinoshi[='s Avatar
fight ninja! ya!
When my car started to stop producing hot air, i went to Acura and told them about my little problem. "We'll take a look at it." they said. It turns out that I had inverted the coolent reserve bottle while changing the cornner lights on the drivers side (you know you gotta remove it)
I'm just guessing, but hope this helps.
P.S have you done anything under the hood recently?
Old Apr 20, 2004 | 12:03 PM
Cornflake's Avatar
Reppin' the T-Dot!!
Yup. That will cause too much coolant to drain out of the rad. Mine had the same problem, I had to be on the gas for warm air to get out. Topped off the rad, ran for a few days, topped it off again and it's been fine. Check the coolant level, but check it from the rad, when it's cool, not the reserve bottle.
Old Apr 20, 2004 | 01:08 PM
I think I'll try topping off the Rad tonight afterwork, I've checked the reserve bottle and it is always filled between the Min/Max marks but I've never taken the rad cap off to check.
Note: I have not done anything under the hood since my last visit to the dealership 2 months ago.
I think these are great ideas, if anyone has another please reply.
Thanks.
cycdaniel
Dec 17, 2019 10:58 AM
01CLOwner
Oct 9, 2015 01:07 PM
mv01
Sep 15, 2015 10:36 AM
Bahamanurse1
Sep 10, 2015 10:05 PM
Redsand353
Sep 6, 2015 01:03 PM
