Heated Oxygen Sensor - Bank 1 Sensor 2
Hi everyone, got the error code P0141 for my 1997 Acura 2.5TL when I took it into Autozone as my check engine light was on. Secondary H02S12 (Heated Oxygen Sensor - Bank 1 Sensor 2) circuit heater malfunction.
Which one is this, pre or post cat?
My dad is pretty good with cars, he said he can deal with a universal one and do the splicing into the harness and whatnot. So I plan on just getting a new one.
Probably gonna buy it off this website, which one would you suggest?
http://www.discounto2sensor.com/stor...735+4294965653
Thanks for your time!
Sensor 2 is aft of catalytic converter.
Ebay is easiest site to buy from w/ buyer protection built-in and usually lowest prices, but check amazon.com, and rockauto.com. All are very good. I've used ebay for 5-6 years w/only one issue which was resolved.
You can verify sensor is bad by checking resistance (ohms) of heater circuit (two same color wires). Resistance of a bad sensor should be either infinite-open or zero-shorted.
good luck
good luck
I am deciding on which I should buy. One states that it is heated the other doesnt state anything but is Denso which is the OE.
Which should I get the Replacement one or the Denso one?
http://www.discounto2sensor.com/stor...en%20Sensor%29
Jul 16, 2017 07:33 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
