Headlight Questions
Headlight Questions
Ok my headlights don't look even when lit at night. I know there must be an adjustment somewhere to try and even them up. Any sudgestions on how to fix this problem??? Also I have a questions as to which alarm I should get for my TL any sudgestions???
Ok, do you mean that they don't look even as in brightness or they don't look even in alignment (like one beam seems to be pointing higher then the other)?
For an alarm, I'll say Viper as well. I don't have one but I've herd good things about it.
Reppin' the T-Dot!!
1 Post
Yeah, if you can't aford HID's, go with some good H4 bulbs. I never thought the stock was THAT bad, and I like bright headlights, but there is no comparison to the HID's. There are adjustment wheels in the back of the lights I believe for the angle. I have a CodeAlarm 2-way, GREAT alarm. Two way paging, remote start, works very well and good range.
yeah there are wheels for adjusting the beams on the headlights. you'll need a long ass screwdriver to reach those wheels... once you get a long enough screwdriver just turn the screw driver to adjust the beams accordingly... there's also wheels for the fog lights as well....if you have the manual it'll tell you exactly where and how to adjust the headlight/fog light beams.
hey deluxe...... im sellling a 2 way alarm.. its the CLIFFORD MATRIX RS III. i dont know if any of you guys heard about it.... DIRECTED is the company that makes both the clifford and viper alarms... u can goto www.directed.com for more info... or goto google and type in clifford matrix RS 3 or III and alot of info would pop up about it...... i'll also include a free battery backup to power the alarm if ur battery gets disconnected and relays you need to install it....... i paid $500 for it..... im sellin for $300....... its brand new in the box with all papers and cards.... matter of fact. i still have it in bag of the store i bought it from....
TL no more!
I'm sorry for bring such an old thread back up but I have a question. What's the difference between a stock 9003 bulb and an H4 bulb?? Both have the same wattage and life, why is H4 better than a stock 9003??
Can I safely assume that an H4 bulb fit into our stock location without modifications??
actually 9003 and h4's are very similar that they can both be used. i think the difference is the type of housing your suppose to use it in. H4's or 9003 will both work. I currently have 9003's but h4's are stock.
BoricuaTL
04-08-2016 01:08 PM
pistacio
09-26-2015 09:45 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
