Headlight bulb replacement
Old Oct 30, 2006 | 05:37 PM
stratocon's Avatar
4th Gear
New member with a 98 2.5 TL. I would like to replace the old headlight bulbs but the retainer clip is giving me a fit. Any tips???
Old Oct 30, 2006 | 05:38 PM
daemonicus's Avatar
how is it giving you a fit? is it not releasing?
Old Oct 30, 2006 | 05:42 PM
stratocon's Avatar
4th Gear
yes it released but I cannot seem to get it back in.
Old Oct 30, 2006 | 07:35 PM
stratocon's Avatar
4th Gear
Any help????? How do I install the clip???
Old Oct 30, 2006 | 09:29 PM
daemonicus's Avatar
well if you got it released, it just goes back in the same way. you put the new bulb in (make sure it's fit the right way) and then put the clip on the bulb and push down in it and it should slide under the retainer. maybe you just didn't push down on the clip.
Old Oct 30, 2006 | 09:41 PM
stratocon's Avatar
4th Gear
Problem was the clip popped out. I will give it another try.... Thanks
Old Nov 2, 2006 | 10:41 AM
TimmyPB's Avatar
i had troubles with it also, but you just have to fidget with it and careful maneuver your hands to get it back in. gl.
acuraST
Sep 17, 2015 02:31 AM
theinsvnity
Sep 10, 2015 10:22 PM
spiel08
Sep 7, 2015 08:19 PM
brjones9
Sep 3, 2015 07:30 PM
voigt
Sep 2, 2015 10:44 PM
