Head Unit Installation Question
giggity giggity giggity
When I just did mine last week, the manual that came with the sleeving gave detailed instructions with pictures. If you want, I can scan it in and e-mail it to you.
HQuakers: my email is mike@gtspec.com just in case.
If it is too much trouble to scan and email, you can just give me some instructions
Thanks again.
Thanks again.
I will e-mail it to you asap.... it includes pictures, so that's why it would be better for me to e-mail it rather than typing the instructions here...
Become Hypnotized
HQuakers or GTspecNYC if either of u guys care can u send me a copy of those pictures also at d3rk@hiwaay.net
Thanks,
Derek
Thanks,
Derek
Ex-Mod
Make sure you have your anti-theft code or else the radio won’t work anymore once you unplug it.
1 - Take a flathead screwdriver and wrap the tip in an old shirt or rag. Slowly and gently begin popping off the wood trim starting on the passenger side. Just insert the screwdriver in between the dash and wood and pry it out. Be careful around the radio where the wood gets thinner. You might want to use you fingers on that part.
2 - Once the wood is off you’ll see that the climate control unit is connected to it. Unplug the 2 plugs behind the climate and completely take the wood trim & climate control unit out.
3 - Remove the 4 philips screws holding the black trim around the headunit out.
4 - The headunit should now pull out.
Originally posted by HQuakers
I think the code is on the radio somethwere...heh heh, if that helps...
Soul_Deamon
11-13-2018 04:44 PM
Skirmich
09-15-2015 06:41 PM
