head light issues
Old Mar 22, 2005 | 04:32 AM
jaimelynn1's Avatar
8th Gear
head light issues
Unfortunately in December of 03 I hit a very large deer. 1 month and $5000 dollars later I finally got my car back. Ever since then, a head light last only a few months at best before it blows.
Today I replaced my drivers side headlight, and it was out by the night time. Is this in correlation to the accident, or has anyone else had headlight problems in the older model TLs. (97 3.2)
Thanks for any help you can give me.
Old Mar 22, 2005 | 06:12 AM
UnsanePyro's Avatar
Registered Driver
It could be a problem with the accident, some sort of electrical problem that is sending the light too much current, causing it to blow? Does it shine brighter then the other one without the problem?
Old Mar 22, 2005 | 07:57 AM
Cornflake's Avatar
Reppin' the T-Dot!!
Yeah, the super white bulbs never last as long as the normal Halogens, but a couple of months to not even ONE DAY is a little extreme. Ther's probably either a short or some other kind of electrical problem. Do you have a decent voltmeter and ammeter that you can run some quick tests to check the voltage and current draw of the light?
Old Mar 31, 2005 | 02:53 AM
jaimelynn1's Avatar
8th Gear
As a matter of fact cornflake, I do use the super blue lights. I find that the actually do help me see better at night (poor night vision, guess that is why I hit the deer in the first place). But I do not have a voltmeter and ammeter to run test with.
In response to UnsanePyro, the Driver side bulb does burn brighter than the passenger side.
So I guess in either instance you are both right. Thank you for the input!!!
Old Mar 31, 2005 | 11:48 AM
wackjum's Avatar
It could also be something wrong with the housing of the head light assembly, allowing the light bulb to bounce too much and cause it to physically break the filament.
However, that's just a suggestion. I agree it's probably an electrical short.
Old Mar 31, 2005 | 11:31 PM
Cornflake's Avatar
Reppin' the T-Dot!!
Good thought wackjum....that is entirely possible.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
Ny1718
Sep 11, 2015 09:21 AM
