Gasket Sealant
Gasket Sealant
Is it ok to use gasket sealant with the OEM gasket, the paper type, for tranny? There seems to be small leak when I changed the tranny filter and I ma not sure what to do now.
~Cheers~
Originally Posted by KaMLuNg
yes i will actually be doing that this weekend.. i also have same issue.
I will make sure tomorrow that the upper flange of the tranny has no left over old gasket, I will scrape it out all the way. I will clean both tranny pan and upper flange with brake cleaner.
than I will apply gasket sealant on the tranny pan than put the gasket and apply sealant on the top part of the gasket.
Let me know if this sounds right.
ok, I was able to stop the tranny pan leak by sealing the gaskets' both side with Gasket Sealant.
So, anyone planning to change the tranny filter, please use Gasket sealant with your new gasket, otherwise IT WILL LEAK.
Car shift very smooth now and there is a diference.
Thanks KaMLuNg for the nice DIY write up.
i just resealed my tranny pan gasket on saturday... i actually even took some sandpaper to smooth off the edges of the pan first... a good little tip, i will add into my writeup because i think i forgot to include that step... will check my parking spot in the garage this afternoon when i get home.. fingers crossed
If the car is not driven, should the dip stick register any fluid? Mine does not register any even after adding 3 qts.
cycdaniel
12-17-2019 10:58 AM
InFaMouSLink
10-27-2015 06:52 PM
