Fog's bulbs
Fog's bulbs
Some previous posts, someone said that the bulbs for the fogs are H3-C. However, when I went out to shop for the that type of bulbs. They're not available. Only H3 as in the picture:
And this is no where near the same kind of bulbs using for the fogs.
Anyone know where to get this bulbs in Superwhite?
![](http://www.piaa.com/images/h3bulb_03.jpg)
I found this link from the previous post from 96TL:
http://www.hitechimportlighting.com/piaa.htm
I wonder why the PIAA's website didn't list this item (h3c bulbs)
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Ex-Mod
They are very rare. You can get H3 bulbs to work though. The bulb is a perfect fit, but the plug is different. You would have to ground the bulb mounting ring to the headlight plug.
Ex-Mod
Originally posted by TLover8888
i got hyperwhite H3 bulbs that fit perfectly with no modification to them from Tim...about 40 bucks
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Ex-Mod
It can work if you ground the light assembly. If you get a test light and find the ground in the foglight plug and run a short wire from there and attach it to the light assembly that holds the bulb in it would work. You would just have to find some way to attach it to the light assembly. Maybe with a ring connector around the screw that holds the light assembly together. Its ALOT easier to find H3 bulbs than H3C. Thats the only website I've ever seen that sells them. You have to send them an international postal money order. Its a pain. I went through it already.
Originally posted by 96TL
How do they get ground? H3 bulbs only have 1 wire for power. The ring aroung the bulb si ground when its in the light but it won't work on our car. I tried it.
my fault...Tim sent me H3C fog light bulbs because they looked exactly like the OEM ones. i just took out the OEM ones and put the ones from Tim right in (of course, i took out that yellow condom-looking thing first).
Guest
Posts: n/a
I'd like to do the same... How did you remove the yellow condom-looking thing?
Ex-Mod
Originally posted by MaxxT
Well how do you do it?? come on!!!
if i remember right, you have to take out the fog light bulb. then, there are two screws, one on the top and one on the bottom. unscrew the top one completely off BUT ONLY LOOSEN THE BOTTOM ONE because it will be a ***** to put it back in if you take it completely off, trust me. then, the whole fog light assembly will come out and you will see the yellow condom. just pull out the yellow condom and there you go.
if these instructions are a bit confusing, do a search for the procedure because thats how i got instructions to do it.
Ex-Mod
