Foglights
Old Aug 11, 2002 | 09:24 PM
Foglights
hey guys one questions. Will h3 fit my 97 tl foglights
Old Aug 11, 2002 | 09:49 PM
962.5tl's Avatar
yes
0but you have to modify it a little bit
1st take the current H3C bulb out
2nd take a piece of wire 6-10 inches long
3rd there is a screw inside the headlight by where the fog bulb would be , unscrew it a little
4th take a spade terminal ( if you dont have one you CAN strip the wire a little and wrap it around the screw )
5th screw it back in
6th run the wire out to the plug for the fog bulb
7th put the H3 bulb in
8th get a male conector for radio shack or something like that and take the plastic surround off of it with a razor blade or something that will cut
9th you should now be able to plug both of them into the factory plug do this and the i reccomend some tape to keep it tight
your done it is pretty easy to doo , post if you have any more questions
Old Aug 14, 2002 | 09:54 PM
is it for a 2.5 or 3.2?the h3, i just got my black housing headlights from japan and they are for a 2.5 tl they fit perfect, one question though does a 2.5 in the corners lights the whole seen to be a bit bigger though i dont know if the car from here have it the same way or it just the headlight from over there , i could modified that,that's no biggy but i need to know if the 2.5 from here have it the same way though?
Old Aug 15, 2002 | 09:02 AM
FSUPaintball's Avatar
7th Gear
To convert my H3s into H3C's, I just soldiered a wire to the side of the metal foglight housing, crimped a connector to the end (connector purchased at walmart -- same size as the original connector) and plugged both the original wire and the newly sodiered wire into the foglight wiring harness. This method has worked fine for the fast 3 months with no problems. I have pictures if needed....
quanaman
Jan 9, 2023 07:33 PM
Jul 16, 2017 07:33 AM
shinybluecls
Nov 16, 2005 12:00 PM
ST2000
Aug 14, 2003 02:47 PM
