Flush Anti-Freeze
Flush Anti-Freeze
I just took my car in to get the tires rotated and balanced and the guys came back and said that my anti-freeze failed the acidity test and that I need to get it flushed. Is there a way to do this by myself? Do I need to get it done?
Thanks.
Thanks.
98 3.2 Flamenco Black
What?? Acidity?? Rip Off.
Yes, you can do it yourself. Drain and fill. Get the Honda pre-mixed Coolant, $9.00 per Gallon, you will need at least 2 gallons.
Drain the radiator and coolant reservoir. Fill.
Simple.
Simple.
Ok, man, post it, I am due for it, too. Thanks in advance. I guess you will tell us to drain the engine block, too. Works for me. You will need a thread sealant, which I got already.
You will have to take off the battery yo get to the bleed bolt. I did my research but forgot already.
mada51589
05-03-2022 08:54 PM
STL TL-S
09-23-2015 08:52 PM
