Evaporator drain tubes on acura 2.5 tl
Old 07-23-2012, 12:30 PM
General Automag's Avatar
Does anyone have or know of a link to a schematic diagram showing the location of the A/C evaporator drain tubes on a 1997 2.5 TL?
Water has built up somewhere and we can hear it sloshing around. It sounds like it's right behind the dash board. I'm told that there are drain tubes that can be cleaned up, which I believe is the cause of the problem. There is a moldy and musty smell too, so I'm sure that's the cause.
I tried a manual from Chilton's, but it does not give enough detail. Thanks!!!
Old 07-24-2012, 07:53 AM
icecoldone1906's Avatar
The is one that is right above the flex pipe on you exhaust. It is the drain tube for the AC....
TL-Rocket
04-29-2023 02:33 AM
cobra10363
01-16-2021 08:12 PM
cycdaniel
12-17-2019 10:58 AM
IIDXholic
10-08-2015 07:53 AM
DDTsx06
09-08-2015 06:56 PM
Quick Reply: Evaporator drain tubes on acura 2.5 tl
