corner light problem
Old May 12, 2005 | 09:32 AM
LeathaFace's Avatar
Str8 Rida
aight so this is tha thing i've had my clear corner/bumper lights for a few weeks now (maybe 2-2 1/2) and the other day i noticed my left corner light hangin' so im like WTF, so i took off tha whole assembly and looked for tha problem and there it is the place where u screw in tha screw it chipped off EXAMPLE: instead of a full circle its like a half moon if u get it) so its no way tha screw or light stays in..it doesnt hang like a eyeball out of tha socket all tacky ir nuthin like that so im tha only 1 who knows...but ti juz urks me and i hate to get out of tha car and push it in everytime...it only stays in because tha turn signal holds it i guess....so in conclusion does anyone have any bright ideas on how to fix this or has it happen to anyone else? cuz im typin with one hand with tha crazy glue in tha other..... ( only thing if u se crazy glue how will i get it back out again to change tha bulbs if neccassary?) dammit pls help
Old May 12, 2005 | 09:57 AM
2doe's Avatar
have u thought of some silcone? or just regular glue?
Old May 13, 2005 | 08:40 PM
KMS-TL's Avatar
Fk U, Pay me
if the missing piece is still attached to the screw, epoxy those suckers together real tight and sand it down a little till it fits (may have to re-drill the hole)... it will be stronger than original...
if it isn't, well, don't do anything TOO permanent.... actually, if you find a piece of plastic similar to the missing piece, you can use that- it'll take a little glue and sanding, but should be just fine....
my
update when ur done, homie....
Old May 14, 2005 | 01:17 PM
LeathaFace's Avatar
Str8 Rida
aight thanx ill try those ideas and see whut i can do.
Old May 14, 2005 | 02:00 PM
UnsanePyro's Avatar
Registered Driver
Hmm.
The tab on the bumper for my corner light is also a half moon sort of shape (took it off to fix the wiring yesterday). On the screw I have though, there is a U shaped piece of metal that wraps around the mounting tab on the car.
I should make a picture of it or something.
Old May 14, 2005 | 10:01 PM
LeathaFace's Avatar
Str8 Rida
yea its kinda like where u screw tha screw in its half moon so tha screw doesnt hold in place.. it'll juz fall out tha open side ..im screwed...no puin intended..lol
cycdaniel
Dec 17, 2019 10:58 AM
HeloDown
Sep 8, 2015 06:51 PM
voigt
Sep 2, 2015 10:44 PM
bymotion
Aug 31, 2015 05:00 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
