Compression ratio!!
Compression ratio!!
Hi guys im a newbie here, just got my 98 2.5 tl last week. I have few questions here: What type of oil is required for this car, example 5w-30, 10w-30 etc? how many quarts should i put in it? Now the fun part Im very interested in fabricating a turbo setup for my tl, I have done few custom setups for mostly for honda. Does any one know what the compression ratio of a 98 2.5 tl is? How big are the stock injectors, what cc's?
![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
Received 2,329 Likes
Compression ratio is 9.6:1 in both motors.
thanks guys, so that means that I will get a shop to custom make a 2 m.m head gasket that will drop the compression somewhere in the 9's. cool
Dont fiddle around with headgaskets.. its actually the only real weakspot on our cars.
the reason why I suggested that is because I thought the compression ratio was in the 10's. My last car was a civic hatch, b18c5,t3/t4 turbo kit since the engine has a high compression ratio, I had inline pro make me a custom 3.0 m.m head gasket with I never had any problems with. the car made 327whp, 240 ft pounds of torque.
to drop the compression ratio the head gasket dosent get thinner it gets thicker. Because on the B18c5 the oem head gasket was like .50 m.m and to drop the compression ratio it became 3.0 m.m.
Professional EFI Tuner
Originally Posted by ljmushock
Yeah, what he said about the oil and stuff. So your thinking about a custom head gasket? I unsure about that... I worked in a parts store with a machine shop for three years. After seeing what blown head gaskets, burnt valves, and warped heads look like I cant see why you would want it any thinner... You could have the head resurfaced to drop the compresion, but it would be minimal. Fill me in on the logic of a thinner head gasket...
which parts store you work for ? I am in Lawrenceville, I work in Norcross.
Originally Posted by meazz1
ljmushock, which part of town you are in ?
1fatcrxnem1
22
06-01-2018 01:23 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
09-15-2015 06:44 PM
