CD player in 1g TL doesn't work!!! CDP-EO
Old Jan 2, 2010 | 11:22 AM
Mr Sand TL's Avatar
7th Gear
Question CD player in 1g TL doesn't work!!! CDP-EO
I just purchased my TL a few weeks back and have found the cd player doesn't play cd's! The stock system sounds great but I am forced to bow to FM's demands. When I put the CD in the screen says CDP-EO then ejects the cd. Does anyone know what this means or how to correct this? I like the look and simplicity of the stock head unit (minus the tape player, but realize tapes still existed in 97). I searched and searched but cannot find any good info. I did read someone's post about using a 2g head unit in a 1g but the post didn't elaborate. Also, an aftermarket head unit would be ok but like I said I like the integrated look and finish of the stocker and I dont' really care about navi. This is my very first post so any and ALL info will be appreciated. This TL is also my first stab at a Honda, I graduated from a 2g eclipse gst. Anyone with anything for sale would be helpful too but don't cheat a newbie...that's just wrong! Thanks.
Old Jan 2, 2010 | 11:28 AM
TLin401's Avatar
'13 Hyundai Sonata
Your CD player is not able to read a CD that you burn. I had this same problem when I first got my car and then I just said f it and got an aftermarket headunit with CD player and iPod intergration.
Old Jan 2, 2010 | 11:48 AM
Mr Sand TL's Avatar
7th Gear
well it does the exact same thing on a non-burned cd also. Looking at the common problems sticky I'm seeing many people with the same problem. guess I need an aftermarket but I just wanted it too look classy. I don't care about navi and don't really plan to have subs or anything I just want a decent-looking DD unit to play CD's. thanks
Old Jan 2, 2010 | 12:52 PM
simm's Avatar
98 Blue 2.5 TL 200,050 mi
I got a single din head unit - works great! Just get the mounting kit from Crutchfield.
Or look on Crutchfield and see the dual din options they have. Then look on craigslist or Amazon for cheap ones. I got my Kenwood Bluetooth and USB HU off a guy on CL for $130. I took a risk by simply trusting the guy that it worked. Well, it did!
Old Jan 2, 2010 | 01:03 PM
Go90go's Avatar
大日本帝国
^ Simm, did you get the light I sent?
Back on topic, I got a single din, too.
~Cheers~
Old Jan 2, 2010 | 01:17 PM
vas25tl's Avatar
The Box
I've had 2 1st gen TL's, both had faulty cd players - replaced them with an aftermarket single din in both cars.
Old Jan 2, 2010 | 01:50 PM
DAiNiUS's Avatar
Yeah I have the same problem too. Someone on here actually took the head-unit apart and cleaned everything (if I remember well), put it back together and it started working again. Another option is to get an iPod/MP3 player adapter that connects to the CD changer outputs. You can also get a cassette adapter which is what I am using until I get a 2din head-unit. There are some pretty good looking 2din HU's that are moderately priced, so if you want it to look more-or-less stock you should go for a double din in my opinion.
Old Jan 2, 2010 | 04:10 PM
simm's Avatar
Go90go, Yes, I got the light today - thanks! But it doesn't go in the d4 light location! So I put it in the 'overhead' lighting in the dash but it doesn't work. humph. It seems the d4 light is a special bulb (long shaft thingy)..
I ordered 10 or so LED's just like the one you sent to replace the cig lighter, shift plate light, etc.
DAiNiUS, I tried cleaning out the whole system as well (stripped it down to bits and pieces), but to no avail. Still the good ole CDPEO code. So that's why I replaced the HU and now have my favorite music on a tiny little 8GB USB drive in my glove box.
Old Jan 2, 2010 | 06:58 PM
main70072's Avatar
That stock CD player can be very picky. Mines would not read any burn CDs when damp outside. Problem solved with an aftermarket HU.
Old Jan 2, 2010 | 08:42 PM
Go90go's Avatar
大日本帝国
You have to flip it around! LEDs are polarised, so try flipping it around. If the ones you ordered are like the one I sent you, then you'll like the cigarette lighter but you'll hate it in the shifter, coin tray, and overheads.
~Cheers~
Old Jan 2, 2010 | 11:22 PM
simm's Avatar
Thanks, I'll check that out. Do you know where I could get some LED replacements for the D4, D3, D2, and D1 lights? They don't look like anything I have seen in the LED world..
And why would I hate the LED's in the shifter and other mentioned places? Are they not 'ambient' enough? I could just sand them down.
Old Jan 2, 2010 | 11:34 PM
Go90go's Avatar
大日本帝国
I made my shifter light housing into a reflector housing, and it spread the three LEDs I have in there much more evenly. I also removed the diffuser panel that's in there.
~Cheers~
Old Jan 4, 2010 | 03:39 PM
Mandy's Avatar
98 3.2 Flamenco Black
Try cleaning the CD player...might work!
Old Jan 4, 2010 | 06:21 PM
simm's Avatar
Yeah, I used a CD cleaner with the little brush thingy on it...to no avail.
Old Jan 12, 2010 | 12:14 AM
9632tl's Avatar
Radical Member
I had the same problem. I bought a "cleaner cd" and put it in. it ejected it like 9 times, but finally accepted it and it worked. mine plays all cds, even burnt.
The used carlot I got it from bought me a new deck, because I complained about it.
If you want it, we could work something out. mine is a 96
Old Jan 12, 2010 | 01:00 AM
Ken1997TL's Avatar
Stock player will read burned CD's as long as they're decent quality. Don't buy cheap blank CDs. Stick to Sony etc.
Old Jan 12, 2010 | 01:27 AM
Go90go's Avatar
大日本帝国
^ Taiyo Yuden FTMFW. Actually, Wal*Mart uses Taiyo Yuden media for their Archival PhotoCDs. You can't buy them from them directly, but it shows that the media is archival quality. Cheap discs can have a failure rate as high as 25%!
~Cheers~
Old Jan 12, 2010 | 04:56 AM
desired_speeds's Avatar
take apart the radio and clean the CD player lens with a q-tip and rubbing alcohol. It worked for me. It might work for you.
Old Feb 2, 2010 | 08:21 PM
98ACURA TL3.2's Avatar
Just got my 98 tl 2 days ago and i came across this same issue.
And this is why i joined the forum to see if there was any answers.
But i figured i would buy the tape deck adaptor for my mp3 for the mean time till i get a fix for the cd player. Lots of helpfull tips think im a take the unit apart and clean the lens.
Untilli get my navi/mp3/cd/dvd player
Old Feb 2, 2010 | 08:39 PM
blueninja's Avatar
Is their an OE direct fit radio from a Honda or Acura that will fit in our double din?
Old Feb 2, 2010 | 10:28 PM
9632tl's Avatar
Radical Member
buy a laser lens cleaner. just keep putting it in until it reads. it worked for mine, and now it even plays burned cds.
Old Feb 3, 2010 | 01:38 AM
Go90go's Avatar
大日本帝国
Welcome! Unfortunately, I literally threw out 3 or 4 tape adapters the day before yesterday, otherwise one could've been yours! If I find any more, I'll post it up.
You don't want to go aftermarket? The price/features of an OEM HU can't beat a good aftermarket one.
~Cheers~
Old Feb 4, 2010 | 07:21 AM
Mandy's Avatar
Lens cleaner will work 50% of the time. As earlier said, keep cleaning it until you begin to read CD's.
Old Feb 4, 2010 | 07:24 AM
TLin401's Avatar
'13 Hyundai Sonata
My aftermarket radio doesn't turn on anymore It gets power but doesn't turn on.
//threadjack
Old Feb 4, 2010 | 10:29 AM
spend like a hundred bucks and get a new cd player. I recommend pioneer if you get a lower end one because they still put out good sound.
Old Feb 4, 2010 | 11:08 AM
bigwerm187's Avatar
Str8 Home built
//threadjack
The TL has 2 radio fuses one inside the car and the other in the engine bay. this happened to me when i was sodering my stereo wires.
Old Feb 4, 2010 | 02:30 PM
TLin401's Avatar
'13 Hyundai Sonata
Werm I checked them and they both are good.
Old Feb 6, 2010 | 11:52 AM
blueninja's Avatar
~Cheers~
So..... I guess try and fine an OEM HU that works?
I wish we could use one from a newer or late model Honda or Acura. That's sucks
Old Feb 6, 2010 | 11:56 AM
Ken1997TL's Avatar
The newer ones you'd want arent double din really which is very unfortunate.
Old Feb 6, 2010 | 12:32 PM
TLin401's Avatar
'13 Hyundai Sonata
I hated the stock radio when I had it for all of 5 days.
The CD player in it didn't work so now it is just sitting in my garage.
Old Feb 7, 2010 | 10:45 AM
9632tl's Avatar
Radical Member
I still have an extra one that the used car dealer ordered me. its garanteed to work (thru the junkyard)
I even have the radio code for it.
the dealership paid over $80 for it. if anyone is interested, PM me.
Old Feb 7, 2010 | 11:47 AM
TLin401's Avatar
'13 Hyundai Sonata
Fixed my radio situation yesterday.
Old Feb 8, 2010 | 11:39 AM
Mandy's Avatar
What was wrong with it and how did you resolve it?
Old Feb 8, 2010 | 02:07 PM
TLin401's Avatar
'13 Hyundai Sonata
So for over a year, my rear speakers have not worked. Then last week, my radio stopped working but it was getting power because the light was on where you turn it on. So Saturday I said ef it and I took my radio out. I had Circuit City install it in 2007.
So when I took the radio out, I saw that the install was not clean at all. Those idiots did a shitty job. The harnesses were all tangled up. So I was like hmmmmm. Then I untangled the harness, unplugged everything and then hoped for the best. I turned it and IT TURNED ON! Not only did it turn on, but the rear speakers worked as well!!!
Finally I put everything back and loved it.
Old Feb 9, 2010 | 12:11 AM
Ken1997TL's Avatar
Exposed copper? Improper ground
AndrewS
19
Mar 14, 2024 06:59 PM
Ol'Dave
Sep 5, 2020 02:56 PM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
sockr1
Oct 1, 2015 01:31 AM
acurajj
Sep 19, 2015 03:47 PM
