BUMPEr LIGHts
Old Oct 26, 2001 | 12:50 PM
200hp TL's Avatar
BUMPEr LIGHts
i have seen integras with four piece bumper lights how do you rewire it so when you turn on your parking lights the all four turns on?
Old Oct 27, 2001 | 01:20 AM
ReQuest's Avatar
I've done this on my car, the only exception is that i have fast blinkers. Almost strobing rather, because the fail-safe does not detect any resistance on the blinker line, so if basically thinks that there isn'a bulb there so it strobes really quick as a bulb-out warning.
I haven't had time to do it correctly by adding a resistor, so i decided to keep the look. Not bad really.
I've found this site with an accord who did the same thing, except he used about 10 relays haha...but he did manage to get rid of the fast blinkers.
Just a discretion, if you want I can show you how I wired it. Pretty simple if you use a couple relays on each side. Also, I had to cut the complete connection off of the factory car wiring. So If you don't want to take that risk, I really don't think there is any other way.
Let me know, I will post a diagram to how I wired my relays.
Old Oct 27, 2001 | 02:27 AM
200hp TL's Avatar
that would be great if you could post a diagram. thanks. what else did you do to your car beside rims and a system ... engine most importantly.. if you can lemmie see a pic of your car.. and engine...thanks a lot.
Old Oct 30, 2001 | 08:26 PM
Inf4life's Avatar
i think i can save you a lot of trouble. just go out and buy a 7443 bulb. it's a dual filament. which means that it'll stay on when you turn your parking lights on and then blink when you hit the blinker. no need to rewire anything.
Old Oct 30, 2001 | 09:04 PM
96TL's Avatar
Ex-Mod
That wont work. Where is the extra filament gonna get power from? I have 7443's and they dont stay lit up. I thought about getting 7443 plugs and running the extra wire to the parking lights but I'm not sure if they'll mount into the blinker slot.
Old Oct 31, 2001 | 10:29 AM
Yes, like 96TL said - it won't work if you just replace the 7440 bulbs with the 7443 bulbs.
First, I thought if I could buy the connector of our rear-brakelight since the bulbs are 7443 (double filaments) - One stay one and one lid when the brake pedal is pressed.
I found out yesterday, that the connector won't fit the signal light housing. The signal light also has three wires instead of two. One uses for signal, one uses for hazard.
So, i'm stuck right there. Anyone else has any other suggestion?
I'm thinking about apply another bulb in the signal housing. Drill a hole, and add another bulb, then connect that bulb to parking.
Old Oct 31, 2001 | 10:48 AM
Inf4life's Avatar
well, thanks for clearing that issue up with me. i would like to get my lights to stay on all the time but i'm not about to dump mad flow to get my car rewired. it's just not worth it. if anyone comes up with a simple, cheap way to do it please let me know.
handsom-hustla
Nov 13, 2015 05:04 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
PortlandRL
Sep 14, 2015 12:01 PM
ellisd03tls
Sep 8, 2015 04:17 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
