belts tention adjustment
I had the timing belts, and other belts, water pump replaced about 10 months ago. Do these belts need to be adjusted one more time to make sure they have the correct tension? I do not hear any noise now but just want to be cautious.
they usually don't need to be adjusted unless you do hear noise.. usually if there is noise, the belt is prob loose and needs to be tightened... happened with my AC belt on my corolla... but just listen... if no noise then its okay..
