Automatic Car Starter ?
Old Nov 13, 2003 | 10:51 AM
4th Gear
I was thinking of getting an automatic car starter installed in my 1998 2.5TL. Any thoughts? Problem areas or products I should be aware of in case someone feeds me a line at the store?
Thanks.
Old Nov 13, 2003 | 02:19 PM
morningla's Avatar
that's a fairly common add-on for people in cold cities. i have compu star install. the only thing you have to be careful is make sure the technician knows how to by-pass your factory alarm, so your factory alarm won't go off when the engine starts. and you don't have to go back.
You are selecting between a starter or alarm/starter combo, deciding on the range, a 1 way or 2 way remote. You can get a lot of info at a&b, future shop, and canadian tire. then you can actually purchase the device from car shops, they usually have promotions right about now.
if you park outdoor, it's a good investment
Old Nov 13, 2003 | 06:13 PM
98tlracer's Avatar
I have the Aladdin 2000. Been using it for over a year now. So far so good.
Old Nov 13, 2003 | 11:05 PM
Din's Avatar
Din
Viper makes good car alarms with remote start.
Old Nov 14, 2003 | 07:40 AM
Cornflake's Avatar
Reppin' the T-Dot!!
I have a ProStart on my 3.2, works great!! Only problem I have now is that I gotta change the thermostat! ENGINE warms up fine, but no hot air through the vents until i give it some gas, kinda sucks, but I just haven't had time to get the thermostat changed. Prolly do it this weekend.
Old Jan 2, 2004 | 05:12 PM
lrpalmer3's Avatar
4th Gear
help
Conflake, where did you get the wire codes for you 97 TL? I'm trying to install my car starter and am having problems with the info I've pulled off the web.
Old Jan 2, 2004 | 07:13 PM
KaMLuNg's Avatar
crimestopper... 2 yrs now.. still works like a champ....
Old Jan 10, 2004 | 11:49 PM
i got an autopage alarm. the alarm came with a pager remote, thermometer, and remote start. the only thing that sucks is that when i gets cold the remote start doesnt work, you have to activate the remote start twice
Old Jan 11, 2004 | 12:04 AM
lrpalmer3's Avatar
4th Gear
Sounds like you didn't get the tachometer hooked up. If you did, the starter would crank until the car started. Since you didn't, it just cranks for 2 seconds. Your installer went the easy way.
Old Jan 11, 2004 | 01:01 AM
I just got a crimestopper i love it the 2 way FM CS20015 its awesome
Old Jan 11, 2004 | 09:55 PM
tight, thank for the info. they told me that its normal because something in the alarm is external not internal like the dei alarms
Old Jan 11, 2004 | 10:48 PM
SamZman's Avatar
That's what I went with and love it.
Old Jan 12, 2004 | 10:41 AM
praxiis's Avatar
I just had one installed on friday - a Valet (DEI, Viper, etc). I love it - much better range than the old remote, plus the lights flash (including the fogs, since I did the fog rewire).
Craig
Old Jan 12, 2004 | 02:42 PM
does any one on here have a 2 way alarm i just bought one and was wondering if any one elese has one and how well theres works.
Old Jan 12, 2004 | 03:11 PM
morningla's Avatar
mine is 2 way, command start/alarm, it's fairly good, good distance, except my sensitivity is too high, alarm goes off when trucks pass by. alarm is also affected when the engine gets wet, control will go temporary unavailable for a few minutes.
Old Jan 12, 2004 | 05:53 PM
Yeah i just turned my sensitivity down, at first i also had the problem of like accidently unlocking mine in my pocket. I found out my alarm could be set to be used on diff cars, so i just change the setting from car to car 2 when i put it in my pocket and problem solved.
cobra10363
Jul 23, 2024 04:13 PM
peti1212
ILX
22
Jan 5, 2022 05:14 PM
Feb 25, 2020 09:57 AM
dlknight
Sep 3, 2015 07:54 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
