audio problem help!!
Old Dec 26, 2006 | 12:32 AM
hinesktchp's Avatar
woord to ya mother
my amp wont turn on and i think it might be because of a bad ground, heres what happened:
i put a cd and turned it up to 20 on my stereo (high) and as soon as the first beat hit, my music shut off- i restarted my car and it was fine.
a day later i was driving and again, my music shut off, but after a restart came back on.
the next day my music shut off, but i didnt notice until i had stopped, restarted car and it still didnt work, however when i turned my stereo on the blue power led lit up on the amp for about 2 seconds then faded off
now when i turn on the power, the led does not light up at all, not even flicker
i need to know where you guys with systems have your amps grounded and also if anyone has any other ideas, let me know, please, i need my music and i just got sirius for xmas and cant enjoy it yet hellpppp
Old Dec 26, 2006 | 05:54 AM
KrayzieDxC's Avatar
Khmer Pride
the channels are dead. i had a problem with my visonik amp..the subwoofer made a loud sound but the sub was fine..the amp on the other hand stop working. you didnt talk about any fuse was there a fuse?
Old Dec 26, 2006 | 08:25 AM
KaMLuNg's Avatar
check the three main lines... ground power and remote...
Old Dec 26, 2006 | 03:49 PM
daemonicus's Avatar
i grounded under the seatbelt bolt right below the panel in between the front foor and the back door. it's all metal under there, perfect place to ground.
Old Dec 27, 2006 | 05:16 PM
hinesktchp's Avatar
woord to ya mother
thanks for the help guys i really appreciate. i checked everything and it looked fine. i finall took out the inline fuse on the power cord and the glass on the fuse had separated from the metal endcap and it was really odd, so the fuse hadnt blown, but it was disconnected, i got a new fuse and it works. i also installed a custom aux in port, sirius radio, and my mio gps system. ill show u pics if u want,
Old Dec 27, 2006 | 05:17 PM
KaMLuNg's Avatar
u should know that!!!
Old Dec 27, 2006 | 07:14 PM
Go90go's Avatar
大日本帝国
My mid/high amp is grounded behind the panel above the lower seatbelt anchor, and my sub amp is grounded in the trunk. +12v is run under the carpet into the engine bay.
~Cheers~
Old Jan 23, 2007 | 12:05 PM
98_2.5_TL's Avatar
TL Enthusiast
Amp grounding
The best place to ground is usually right onto the floor pan. i have 3 amps and a capacitor. i grounded my capacitor near the seat belt bolts, but i created my own ground (drilled a new hole). make sure to scratch off any paint, to expose bare metal.
navtool.com
ILX Audio, Bluetooth, Electronics & Navigation
32
Dec 22, 2015 12:46 PM
navtool.com
14
Oct 31, 2015 08:16 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
siularbar
Sep 11, 2015 10:40 AM
vanderveen44
ILX
Sep 2, 2015 01:48 PM
