Another ABS question
My 96 2.5 ABS light on and off yada yada. Trying to pull ABS codes at the 2 wire connector under glove box. After I install the jumper wire and turn the key on, the ABS light just stay lit. No flashing. Any ideas?
Code 0? "ABS indicator light does not go off after engine is started" is in the 95-98 Online shop manual link on this site.
It appears to be a relatively simple electrical fault in the power supply to the ABS. See electrical diagram Page 19-49 and DTC Symptom-System Chart 19-56.
good luck
good luck
navtool.com
31
Nov 16, 2015 08:30 PM
lanechanger
Oct 13, 2015 10:56 AM
navtool.com
Sep 25, 2015 05:15 PM
