Annoying Window Problem hellp
My driver side or rear drivers side (not sure which one) window leaks air above 45mph. Its not like a huge leakage, but its enough for me to hear even with low music. this kind of stuff drives me nuts. is there a special liquid seal or something i can buy to end it? also i got the whole leaky trunk goin on. Any advice would be awesome. Thanks
my trunk leaked through the gaskets on the taillights, i ordered new one but b4 i did i removed the lights clean the area and reinstalled, no more leaks. as far as the windows is you do a search you will find all the info u need..........
I think the weather stripping is worn away. If you put something on it to bolster it, it shouldn't be a problem anymore (or get new strips). Mine only leaks under high pressure water (like at a carwash) and it's a very small amount.
There is a fix, its on a Pdf file i have in my office, i'll post it on Wednesday.
http://www.a c u r a w o r l d.com/tsb/1997/B97-027.pdf
http://www.a c u r a w o r l d.com/tsb/1997/B97-029.pdf
Just need to take the spaces out of the links.
I'm guessing your window may have fallen out of alignment.
Just observe your windows... you'll notice that the glass (when all the up) actually comes in contact with the black outer plastic guard (or at least come close to it) . If you notice that one window doesn't, it means it's out of alignment.
My passenger window as out of alignment but I got it fixed by my local Acura dealership not too long ago... It was a rather pricy $98.
You might want to check this thread out....
https://acurazine.com/forums/car-parts-sale-361/stock-cl-type-s-springs-%2A%2Afree%2A%2A-81764/
I have not tried it yet, waiting on my speakers so that I can do both, kill two birds with one stone.
AccRight
AccRight
https://acurazine.com/forums/showthread.php?t=81764
AccRight
AccRight
BoricuaTL
04-08-2016 01:08 PM
jaynatlanta
5G TLX Problems & Fixes
09-15-2015 11:08 AM
ahsm
09-09-2015 08:35 AM
