ABS unit
Old Apr 5, 2010 | 10:04 AM
9632tl's Avatar
Radical Member
Question ABS unit
Does anyone know if i can remove the abs motor and still drive the car? I think the pump has an intetnal leak
Old Apr 5, 2010 | 11:14 AM
main70072's Avatar
Yes, you can just remove the ABS motor fuse in the engine compartment. By doing this you will only have normal braking.
Old Apr 5, 2010 | 11:22 AM
9632tl's Avatar
Radical Member
I want to take the motor out and repair it. I have been driving with that fuse pulled already.
Old Apr 5, 2010 | 11:33 AM
TexasHonda's Avatar
Many faults on ABS modulator are not repairable. Leaking oring on the accumulator/modulator connection, leaking body plugs, or leaking reservoir are about all that can be repaired.
Good news is there is a good supply of used modulators for <$100 and maybe <$50. Try car-part.com and look near your zip code. Insist on a "working part garuntee" as the yard will have no way of knowing whether a pulled unit is good or not.
Unit can be pulled by disconnecting electrical and hydraulic connections and loosening mounts. Get a flare tubing wrench (10mm) to loosen the tubing nuts. An open-end 10mm is likely to round them.
good luck
Old May 1, 2010 | 07:49 AM
mdazb's Avatar
Is that what that "buzzing "sound is? Get it about every 25 seconds for about 5 min, then the abs light comes on.
Old May 1, 2010 | 09:57 AM
main70072's Avatar
Yes, it is cycling trying to maintain pressure. Your ABS pump is probably leaking somewhere.
Old May 1, 2010 | 10:10 AM
mdazb's Avatar
Is there a common spot for the leak internally? Is it rebuildable?
dirleton
Aug 6, 2024 08:19 PM
Jamus22
Jun 11, 2023 10:08 AM
brboy
Oct 5, 2015 11:34 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
