ABS Light - Help
Old Mar 12, 2009 | 11:59 AM
ahsanf0377's Avatar
3rd Gear
ABS Light - Help
After changing the rotors and brakes my ABS light is on. I have a 97 Acura 3.2 TL.
Where is the ABS Service connector located in the car and does anybody have the codes.
Let me know.
Old Mar 17, 2009 | 12:08 PM
TexasHonda's Avatar
The service check connector is under the glove box and should be plugged into a plastic holder.
Download the online manual for the ABS code extraction procedure. Flash sequence is different for some years. I don't have manual w/ me now.
To replace the rotors, you may have removed the wheel sensor. Did you re-install?
good luck
Old Mar 18, 2009 | 04:56 AM
Inspired[RUS]'s Avatar
in addition to ^ manyal says:
NOTE: Do not disconnect the wheel sensor connector.
So, if you disconnected sensors, yo'll need to erase 41 or 42 mistake. I did it on HondaScaner, but sometimes puting off battarey's clamp for a while is helpfull. Or may be you just cut off some wires there.
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Stu2414
Aug 30, 2015 07:30 PM
