ABS light
ABS light
When starting, a noise begins, sounds like eehhhh...eehhh. After about two minutes sound stops and ABS light comes on. I know this sound is the ABS failing. Can this sound cause other problems with the car?
had the exact same problem. No, it wont affect other functions of the car. Replace the abs modualtor/accumulator unit, and everything should be O.K. Those units are quite costly at dealerships so try to find one at a junkyard or on ebay like I did.
Originally Posted by veo
Thanks for the advice vishnus. I'll look into the modulator but If that sound has no affect on other functions of the car I'll probably leave it.
My ABS light is still on. I think its been about 3-1/2 years now. LoL.
You can get it for a TENTH of that if you look around junkyards.
Even www.acuraautomotiveparts.org has it for under $900
Link
$810 @ Sunnyside Acura
Keep in mind, thats for a NEW one with a 3 year warranty.
Link
Link
Link
Make sure you bleed the ABS and brakes when u replace the modulator/accumulator thing
mada51589
Jan 9, 2025 04:40 PM
