ABS/ Ground problem?
Old Jun 14, 2008 | 08:49 PM
pretty_ricky302's Avatar
OK for some reason my abs light comes on then goes off, also around this time my radio will start acting funny, and resetting itself. I believe the problem could lie in a ground. I grounded the radio (TV) to the ecu metal case. U think this is the problem?
Old Jun 15, 2008 | 07:49 AM
Go90go's Avatar
大日本帝国
Check the fuse in the kick panel. I HIGHLY doubt you grounded the HU to the ECU. The ECU is in the front passenger footwell. You probably grounded it to the ABS computer's casing which I'd recommend you ground it elsewhere.
~Cheers~
Old Jun 15, 2008 | 10:11 AM
ok then i think thats the problem, b/c they both act up at the same time, imma move it.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
DementiaPhuro
Sep 29, 2015 05:31 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
rboller
Sep 23, 2015 02:49 PM
