3.2 tl speakers ?
Old Aug 31, 2003 | 06:25 PM
biggie275's Avatar
3.2 tl speakers ?
acura says that the 3.2 tl has 8 speakers i see two in the front and two in the back where are the other 4 ? are there tweeters next to the dome light ? they look like speakers housings but that still leaves 2 unfound where are they can anyone help me out ?
Old Aug 31, 2003 | 06:28 PM
Ken1997TL's Avatar
There are 4 tweeters, check near the A pillars in the front (near the windshield, they'll be in the corners) 2 tweeters next to the front lightswitch (between the visors) 2 in the front doors and 2 on the rear under the rear glass.
Old Aug 31, 2003 | 06:33 PM
biggie275's Avatar
i just changed to an alpine head unit i dont think they rewired the tweeters . i need to go back and get them done cause they aren't putting out any sound . thanks i thought those were tweeters but was not sure. cool when thise get wired up will sound so good also put in a 12 inch jl audio w6
Old Sep 1, 2003 | 02:32 AM
Mikes96TL03CLS's Avatar
ya we got awesome stock stereos. But mine won't be stock for long....
Old Sep 1, 2003 | 09:45 AM
AC_DADDY's Avatar
ballin and baldin
now to put in a new head unit
what are the resistances' of the speakers in the TL?
are they all 4 ohm?
or are they ran in series or something like that?
is it possible to get all 8 speakers to work with an aftermarket headunit?
Old Sep 1, 2003 | 10:03 AM
I believe they r 4 ohms. As to running the tweeters, you can splice the wires to power them.
I using aftermarket speakers in the doors and the back. The highs are more than I can bear, so I don't think it's neccessary to hook up the stock tweeters.
Old Sep 1, 2003 | 05:35 PM
DoUbLe0's Avatar
the front 4 stock tweeters arent that loud you cant really hear it tho right??
Old Sep 3, 2003 | 08:58 AM
praxiis's Avatar
They're just loud enough to 'move' the sound away from the doors - this way it seems like the sound is all around you. They should be much lower than the door spkrs...
Old Sep 3, 2003 | 01:32 PM
biggie275's Avatar
i know that they wont make a huge difference but if they are there why not use them. i am planning on getting a dvd player that would be some sick surround sound dont you think ?
Old Jan 31, 2012 | 04:00 PM
JustinLinc727's Avatar
Replacing the Speakers on my 96 Acura 3.2 tl
I decided to get an all new sound system for my acura and ended up getting
Kicker DS693
Kicker DS6.2
now all I need is a head unit that I can connect my ipod to and that can power all these speakers. I am also looking to stay relatively cheap! Thanks
Old Feb 10, 2012 | 10:38 PM
AmosEnterprising's Avatar
That separate blue plug is the tweeters. just wire it into your wires for the door speakers. I have all 4 tweeters replaced along with doors an deck speakers running from headunit it sounds beautiful with my 15 RE SE
Old Feb 12, 2012 | 11:36 PM
Go90go's Avatar
大日本帝国
The roof speakers are mids, not tweeters.
~Cheers~
Old Dec 2, 2014 | 10:44 PM
JonnyAndeola's Avatar
4th Gear
Sizes?
okay so does who know the sizes of the different speakers?
Old Dec 14, 2014 | 05:54 PM
Ken1997TL's Avatar
From Acura:
Audio System
The standard audio system in all TL models is an 8-speaker unit with AM/FM stereo/cassette and compact disc player. Speaker selection and location were determined on the basis of the best sound propagation and imaging. There are two 6x9-inch full-range speakers on the rear deck, one 6.5inch full-range speaker mounted on each front door, two 1.5-inch tweeters on the dash top and two 2-inch midrange speakers located in the headliner.
An anti-theft feature renders the unit inoperative if it is removed from the car, until the proper five-digit security code is entered. The system also features a built-in CD control in case the owner chooses to install the optional trunk-mounted CD changer.
4drviper
Apr 23, 2025 07:13 PM
Pham Alvan
Mar 16, 2016 09:17 AM
kb1rl
Sep 30, 2015 10:17 AM
polish_pat
Sep 25, 2015 12:24 PM
