Where is this oil/fluid coming from?
registered pw
I have been smelling something that smells like brakes when i pull into the garage. There isn't anything wrong with the brakes and they are performing normal.
I was under the car today for some reason looking around. Ifound this thick dried liquid that looks like dried oil. I can't see where it may be coming from and am not sure if it's oil. All fluid levels have remained the same but now i will need to keep watching.
Any suggestions?
Any suggestions?
Received 2,329 Likes
Differential fluid?
registered pw
That could be possible. I changed the oil about 1000 miles ago so in that sense it is fresh. I know what oil smells like when it burns and this smells like brakes.
I don't know how the hell i am going to track this leak down. When i took off the lat oil filter i was wondering what the hell the previous mechanic put on it. I think i need to check the diff level if it's possible.
It may be a dealer visit for something like this.
I believe Ive seen this before. There is a small plascti sensor or something behind the timing belt cover and it melts and looks like that.
I dont remember where I read about it, but thats probably what you see.
They frown on posting other sites here, so I will quote what some others said.
I bellieve the part #8 in this diagram is the problem.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Originally Posted by shoptowel
i pulled the left upper timing cover on my 97rl and saw the same thing down at the bottom of the timing cavity and thought oh crap, i have a bad oil leak. but after closer inspection, it did not look like oil. it looked as exactly as you guys are describing it (mine has not made it to the ground yet). behind the left cam pulley is a sensor, (forgot the name of it, maybe crank position sensor?) but anyway it is a black plastic module that houses that sensor and i talked to the service guys at the dealer about it and they said all of them do that and not to worry about it. they said they use to change them out but do not anymore. they said even after the melting has occured, the sensor still works fine. so i am going to leave mine alone.
my suggestion would be to clean up the black spots and keep on driving.
Ok, so this weekend I changed the waterpump which requires pulling the left cam pulley and the plate behind it and I got a good look at what I had described before. I could see the trail of plastic melting all the way down to the bottom of the oil pan and it is coming from that sensor that I was originally talking about. I tried to wipe it up thinking that it would clean off like an oil streak, turns out it has been there a while and my rag just stuck to it. It will take some kind of cleaner (chemical) to clean it off so I just left it and closed it all back up and it still works fine.
PS: Doing this requires taking off all three acc belts, all three timing covers, crank pulley, balancer shaft belt, timing belt, left cam pulley, and face plate behind cam pulley!
So I do not reccomend doing this just to have a peak at it!
Originally Posted by sboggs303
The black goo is the epoxy potting material on the electroninc timing contol module that is behind the timing belt. I had mine replaced with the timing belt. All that did was provide a new supply of black goo for the garage floor. The new modual is no better than the old one and the old one does not stop working just because the epoxy melts. Leave it alone!
registered pw
rep points for you! If everything is going to be fine like what you quoted, i'll just leave it alone.
I noticed three drops of black stuff on my garage floor and had to take a look. It didn't remind me of any fluids but nothing else really made any sense.
i love AZ :gheyhug:
What you’re seeing is melting resin coating on the backside of the Camshaft Position Sensor/Cam Sensor. This is not unusual and believe it or not will not cause any problems, except of course a cruddy looking drip on your garage floor. Eventually it will stop dripping. If you take it to your Acura dealer he should confirm this and try to convince you to install a new one. As long as your RL is running fine don't do it. The cam sensor basically tells you plugs when to fire at the right time.
cycdaniel
12-17-2019 10:58 AM
CheeseyPoofs McNut
10-11-2015 11:25 AM
IndycarFaster
09-11-2015 02:52 PM
