What brand brake pads should i get?
Old 07-23-2009, 01:25 PM
pmendoza502's Avatar
So its time to change my brake pads. (They are getting noisy)
I have the stock OEM brake setup, what pads do you recommend. Im running 18x8.5s right now if that helps narrow down some choices.
Let me know what you guys think and the price!
Im planning on just getting the fronts unless i can get both front and rear for a good price, planning on doing the install myself as well. Worse comes to worse i'll just buy the OEM front brake pads from the acura dealer.
Also, will pads from the TL/CL or G2 Legend fit as well?
THX!
Old 08-18-2009, 08:17 PM
niceone with the RL's Avatar
I get mine from the local acura dealer-very affordable -the price gets away from me at the moment...Rears cost a little less I think...
Old 08-18-2009, 09:20 PM
OLD_HATCH's Avatar
I personally do not like PBR. They stop well but dust is crazy.
I use to buy AEM all the time before they got out of the brake pad game. I think you might be able to find them under the Nissin brand. The higher quality ones.
If you dont do any tracking or race from stop sign to stop sign on a constant basis i say stick with Acura.
Old 08-19-2009, 08:08 AM
Needs to clean up
sr4dt's Avatar
If you want you can try the Duralast Cmax "Gold" pads from Autozone. These are good ceramic pads (low dust, quiete) and come with rubber backed shims like OEM (no squeal) and have lifetime warranty to boot. However make sure that you do not get the CMax (w/o gold) as those will give a good deal of squeal due to metallic shims. IIRC the fronts will be about $90 and rear about $65. I may be way off on the price so don't quote me on that. However every now and then you get promotional pricings from Autozone so check those before you headover.
Old 08-19-2009, 03:55 PM
Jimmay's Avatar
I have the Duramax Cmax pads all around on my RL. It was 50 for front 50 for backs. I dont have any squeal and the car stops well.
Old 08-19-2009, 06:58 PM
i went with ATE brake pads, they are great! stop well, and are quiet...
Old 08-20-2009, 08:33 AM
2000RL's Avatar
Acura OEM brake pads are pretty damn good. I just had a local Acura dealer do a front and rear brake job along with flushing and replacing the the brake fluid on my 2000RL at 90k miles. Front brakes were done previously at 45k miles and rear pads were the original pads and still had about 50% wear left . I did have to have a sticking rear caliper replaced though.
Old 08-20-2009, 09:02 AM
Needs to clean up
sr4dt's Avatar
Jimmay,
Did you reuse the OE shim or use the mettalic shims that came with the CMAX brake pad.
Liberal application of grease will definitely address the squeal. However I felt the Gold ones were more OE like. Both CMAX & CMAX Gold pads are Ceramic so compared to OE both will be an improvement with respect to brake dust and stopping.
Old 08-26-2009, 09:04 PM
4th Gear
dcivic's Avatar
Factory pads there the best qaulity no noise dust is low and will last long.
mada51589
05-03-2022 08:54 PM
08-15-2019 12:58 PM
HOWELLiNC
10-19-2015 03:26 PM
mav888
1G RDX (2007-2012)
09-08-2015 11:49 AM
nishant11
09-02-2015 10:34 AM
Quick Reply: What brand brake pads should i get?
