VSA ABS triangle lights on; need replacement mirror glass
guys, my vsa abs and the triangle w ! light is on. it is intermittent. sometimes it comes on sometimes it does not. is this vehicle speed sensor?
also I need a new/replacement driver side mirror glass(glass only)....where/how can I find this? I prefer to find a used OEM but...
Dealer is the only one that can diagnose those codes, unless you have an older RL that has an ABS service check connector behind the glovebox.
Does it only come at at certain times? ie while turning, accell?
no usually right after i start the car...sometimes it comes on other times it does not
i kinda had the same problem with mine. break fluid was low. and the sensor was shutting off the ABS n VSA n all that. not sure why. dealer said i need new VSA for 2500 but i got soem breakfluid for 6 dollars filled it up
mada51589
05-03-2022 08:54 PM
wusty23jd
09-24-2015 11:41 AM
Skirmich
09-15-2015 06:41 PM
