Stuck intermediate shaft!
Old Feb 13, 2025 | 04:25 PM
Blueking22's Avatar
Hi everyone, I have a 2000 RL and I need to replace the oil pan gasket. I have everything off except the differential. I'm trying to pull back the shaft to remove the differential but it won't budget.
I have the "special" Acura tool and have read everything on the internet over the last week but I have not move it at all. Please someone help! I also have the FSM and followed everything. I don't know what to do. I've really tried before bothering anyone.
Thank you for your time
Ed
Old Feb 14, 2025 | 06:50 AM
Is #16 below what you are trying to remove?
If so, what is the procedure the FSM lays out in removing the part in question?
Old Feb 14, 2025 | 09:45 AM
Blueking22's Avatar
thank you for your time, im trying to slide back the differential shaft so i can remove the front differential to remove the engine on pan. Most people use a large washer and a pry bar. I've done all that and even ordered the "special" acura tool part number 07LAC-PW50101.
Some people say they just pull it outwith thier fingers. I've tried a slide hammer, a full can of pb blaster. I have not moved it!
Old Feb 14, 2025 | 01:36 PM
This is all I can find that shows utilization of the special acura tool 07LAC-PW50101?
It states to 'shift the transmission into the P position to lock the secondary gear.'
It looks like that special tool is the key to success??
Old Feb 22, 2025 | 07:57 AM
Acura00RL's Avatar
@Blueking22 If you are still working on this problem you may want to contact fellow member @1186KA9 who did this job back in Mar/24 and can/may provide more insights/tips to help.
Old Feb 23, 2025 | 07:26 AM
1186KA9's Avatar
Black Ac' Man
Hey. In short, you wanna try to remove the shaft using the tool. You can tighten with a bit of force, but be careful. I broke mine in the ext, shaft. If it feels like you are using too much force, you can put the trans in neutral and rotate the front passenger cv axle/wheel about 20 degrees to try and get the snap ring into position. It is actually somewhat similar to replacing a cv axle concept-wise. Oh, and I wouldn't use PB-Blaster or any other penetrating fluids since it would likely go into the transmission case and the fluid. In fact, I suggest you change the trans fluid before you even start the vehicle again and do a 3x3 flush within 35 miles of putting her back on the road. Penetrating fluid and transmission clutches do not mix well.
FamilyGuy
Sep 16, 2014 08:08 PM
Yenis Sanchez
1G RL (1996-2004)
Aug 20, 2013 07:48 AM
louisville88
Apr 14, 2010 08:18 PM
Billy Sacco
Jan 28, 2007 05:55 PM
nick96acuratl
1G TL (1996-1998)
Apr 24, 2005 03:33 PM
