Strange noise from engine....help?
Old Mar 2, 2011 | 12:43 PM
silver3.5's Avatar
Lately, this noise is getting louder and louder. It's hard to describe but it sounds like metal rubbing against metal and I can't seem to pinpoint it either. My RL has about 130K with the original timing belt and drive belts. I've included a video of the sound. It is more audible if you listen from the front of the A/C condenser or radiator. If anyone knows what is causing this noise, please let me know. It is quite annoying! Thanks.
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid276.photobucket.co m%2Falbums%2Fkk35%2Fhiddude09%2Fstrangenoise.mp4">
Old Mar 2, 2011 | 01:52 PM
ryk's Avatar
ryk
That many miles and you're still on oem belts? I'd be willing to bet it's your timing belt tensioner. That would be included on the replacement of the timing belt and drive belts. It sounds just like normal wear and tear noise. I had the same thing before my tbelt was done. Now it's all quiet.
Old Mar 2, 2011 | 02:15 PM
silver3.5's Avatar
So you're saying you had this exact noise prior to changing the timing and tensioner belts? and after it, it is gone?
Old Mar 2, 2011 | 03:45 PM
3.5RLv-tec?'s Avatar
Could be. Man, you better change the timing belts fast or else you'll need a new engine! Please explain to me why you haven't change the timing belts at 100k?
Old Mar 2, 2011 | 04:09 PM
onebadna1nsx's Avatar
Hello Friend
^ +1
Old Mar 2, 2011 | 05:16 PM
ryk's Avatar
ryk
Exactly.
Here's a list of parts with part numbers and prices for you:
Here's the part #'s and what I paid for them at a local acura dealer.
HP91212-PY3-003 OIL SEAL 00000 $9.40
AC14400-P5A-004 BELT 197RU24 B $62.02
AC14510-P5A-003 ADJUSTER $67.56
AC16176-P5A-004 GSKT, THROTTLE $4.30
AC31110-PY3-A01 BELT, ALTERNAT $18.13
AC38920-P5A-004 BELT, COMPRESS $18.82
AC56992-P5G-003 BELT, P.S. PUM $17.57
AC91213-PY3-003 2 OIL SEALS 35X50 $23.50
AC13440-P5A-004 BELT 69YU15 $23.40
AC19200-P5A-004 WATER PUMP $236.46
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
