Starting issue..need help
Old Nov 10, 2012 | 07:23 PM
Basit06TL's Avatar
Ive been having an issue when the car starts..
Sometimes when i turn the key the dash lights go on like normal,
right when I turn the ignition to start the car goes dead and i hear a faint click or tick sound.
So what ive been doing is disconnecting both battery terminals and reconnecting and this seems to remedy the issue and the car starts. Sometimes i have to disconnect and reconnect a few times over and over becuase the car wont start the first time i reconnect the terminals. I cant figure out what the problem is.. Any help?? Thanks.
Old Nov 12, 2012 | 10:09 AM
phins2rt's Avatar
How old is the battery?
Old Nov 12, 2012 | 11:07 AM
Basit06TL's Avatar
Fairly new. Just put it in not too long ago. I was told to clean off the terminals and that should do it, but the terminals don't look dirt at all other than the positive having alittle dried acid.
Old Nov 12, 2012 | 01:54 PM
phins2rt's Avatar
Maybe give yourself some more time between putting the key in the ignition and then trying to turn it over. There are other threads about doing this too fast and the car can't read the key's chip fast enough to signal all is ok.
Old Nov 12, 2012 | 03:06 PM
MyNameIsEarl's Avatar
Put a volt meter on each terminal of your battery, if you get somewhere around 12v, you know that battery is good.
rockyboy
Aug 4, 2024 10:35 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
jordanboi
Sep 5, 2015 01:33 AM
