Signal Light Problem
Old Dec 27, 2008 | 11:44 AM
yangsta's Avatar
Some reason when I signaled, the signal light in the car just stayed on. Took a look at it and signal light outside stayed on. Turn off the headlight and then signals will work but at the same time, my driver side headlight will flicker while its on. I turn headlights off and then the signal will stay on again. Nothing happens when i try to change and signal the other direction. So basically when the signal gets stuck, it stays lit and I can do anything else to change it.
I'm going to be getting a ticket for failure to signal.
Old Dec 30, 2008 | 02:08 PM
killakill's Avatar
ground
check ground loose connections
Old Dec 30, 2008 | 07:31 PM
yangsta's Avatar
Where would the ground be?
sockr1
Oct 1, 2015 01:31 AM
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
HeloDown
Sep 8, 2015 06:51 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
