rear passenger window not operating
Old Aug 6, 2008 | 01:30 PM
BobbyE's Avatar
3rd Gear
I own a '98RL with a rear window not going up or down. Motor is working but cables are frayed and what appears to be a white plastic clip at top of frame which holds everything in place, is broken.
Can cables and this clip be replaced without replacing motor or is it all one unit? Also, how does one disconnect the cables from the window frame unit? Its a very tight space and I can't figure out how to get the frame part out.
Thanks for any tips anyone may have.
Bob
Old Aug 7, 2008 | 09:55 AM
John N's Avatar
You can replace the cables but its a pain and expensive. I just put a clamp around the cable with the window up so it is non functional which I never use this one.
Old Aug 11, 2008 | 11:20 AM
Cl TypeS 01's Avatar
hey both of my rear windows dont work so can you guys do a write up of how to do this, I dont mind if the windows dont work I just want to be able to keep them up, b/c my back passanger window wont go up all the way.thanks.
Old Aug 12, 2008 | 07:03 AM
John N's Avatar
First get the windows closed by manhandling pushing them up, its tough but it should slide up. Take the panel off and hidden away in the middle behind a metal frame is the coil with the wire that pulls the window up and down. You have to get a 9inch adjustable clamp like the ones for radiator hoses and put it around the coil and tighten it. This will stop the coil and keep the window from going down. Its very hidden and hard, if you can't get in there take it to a garage and have them do it. It will cost some labor about $100 but its better than $300 for a new coil per window.
Old Aug 24, 2008 | 01:10 PM
munionman's Avatar
Rear windows not working
I, too, have two non-operable rear windows on my 1996 3.5RL. When someone has inadvertently tried to lower one of the windows, I've always been able to manually pull the window back up to the closed position. Today, I wasn't so
fortunate. As hard as I pull, the window will only close half way. Can you tell me how to remove the inside door panel so I can access the cables and motor?
Thanks.
Old Aug 26, 2008 | 09:56 AM
SeamusNH's Avatar
munionman,
Go to www.pdftown.com and search on "acura rl". Download the 40 MB tech manual. Lots of diagrams and instructions....
Old Aug 27, 2008 | 11:23 AM
waterpolo820's Avatar
I replaced the regulators at least 6 times on all my windows together.
So what I finally did with the back ones was to mark where the window sits on the guide bar and then bolt it into place. lets just say, no more window movement
Feb 25, 2020 09:57 AM
Fabian43
Jul 13, 2016 09:07 PM
HairyMonkey019
Apr 22, 2016 10:50 PM
Fandango12
1/2G MDX (2001-2013)
Sep 20, 2015 05:25 PM
Dunnik
Sep 14, 2015 02:56 AM
