Is it possible to replace a driver side interior handle with this part?
Can I replace this part of the interior handle with only what I got from a scrap yard or do I need to order the entire interior unit?
Here is the interior broken handle and the replacement part I found, but its only from the back rear. Do I need the entire front handle unit or can I just somehow replace the handle itself in that unit
if there was a way that you could separate the halves, then yes you could replace just the handle...
however, looking at it....there doesnt seem to be a way to separate the halves to get to the handle without breaking the casing.
if you put in the rear case into the drivers side spot, there will be a huge hole or void for the lock button.
it would just be easier to locate or buy the correct housing handle.
justnspace (07-18-2021)
gavriil
09-27-2003 06:35 PM
