possible to change rear view mirror casing?
Old 04-08-2011, 08:13 PM
volsmd99's Avatar
My rear view mirror suffers from the manufacturing issue described in numerous threads on this site.
The color of my rearview mirror is beige. However, the cost of a new one is about $350.00.
I understand that I can purchase a new OEM mirror for a TL that will fit and work exactly as the original for $75.00. However, it is black.
I was wondering if it was possible to use the new mirror with the old casing. Has anyone tried this?
thanks
Old 04-26-2011, 12:43 PM
60mph Soapbox Racer
jerm1386's Avatar
I tried and failed miserably. IIRC the casing is glued together (even more so once the LCD fluid leaks out. my car is grey but i got a tan one from a junk yard for about 10 bucks. the tan one came apart pretty easy because the fluid wasn't leaking, but my original grey one just wouldn't open up at all. so i just sprayed the tan one with some grey primer, it looks fine since there's no other trim next to it to look mismatched.
Of course I was just trying to pry it apart. if you wanted to cut the two halves apart and reglue them once you put the electronics for a new mirror in, that would probably be alright.
Old 04-26-2011, 01:35 PM
phins2rt's Avatar
FWIW, the black casing would probably look fine.
Old 04-26-2011, 02:43 PM
この道は毛むくじゃらのマンコだらけ..
onebadna1nsx's Avatar
My interior is tan, the black mirror doesn't stick out too much. I actually like it.
Old 05-03-2011, 08:18 PM
volsmd99's Avatar
so went with the black mirror. Actually looks pretty good.
Thanks everyone for your opinions.
rockyboy
12-06-2022 02:29 PM
02-25-2020 09:57 AM
Rocktman1
10-31-2015 02:33 PM
Aleax
09-11-2015 11:31 AM
dre707
09-08-2015 08:32 PM
Quick Reply: possible to change rear view mirror casing?
