Let the modding begin!
Old Mar 1, 2008 | 12:01 AM
  #41
Ken1997TL's Avatar
Originally Posted by Socol
How about Type II intake manifold and Cam regrinds?
Yeah, sometime this summer I'll be doing a mild Type II conversion.
  #42
Ken1997TL's Avatar
Originally Posted by BelowRadar
Ken and Zipho..... have you noticed any difference in your MPG, since you took off the resonator ? ? ? ?
No difference. Its purely a noise/sound change.
Old Mar 3, 2008 | 12:37 AM
  #43
Zipho's Avatar
hey ken what do you think of these?
Weapon R Aluminum Billet Fuel Rail Adapter - RL 1996-2002
http://www.eautoworks.com/index20!ma...D!1063!uinv!3.
Old Mar 8, 2008 | 06:37 PM
  #44
Zipho's Avatar
hey ken are thinking about upgrading your suspension?
out of tsx coilovers or legend, tsx better fit?
tein, ksport etc...., preferences?
Old Mar 8, 2008 | 09:29 PM
  #45
Ken1997TL's Avatar
Suspension is fine for my tastes. There is only so much performance you can get out of a FWD car thats just under 4000 pounds..
I'd rather mod the car to have a bit more horsepower. Maybe another 25 or 30.
Old Mar 9, 2008 | 11:14 PM
  #46
Zipho's Avatar
alright, keep us updated. I'd like some more tourqe for a little extra grunt down low.
Old Mar 10, 2008 | 04:01 PM
  #47
Ken1997TL's Avatar
There is plenty of torque. The issue is mostly a matter of torque steer. Acura has tuned the automatic transmission and in particular the torque converter to be a bit more gentle than say a TL Type S. So off the line there is a small dose of hesitation built in from the factory.
How to go around that? Either a higher stall speed for the torque converter or maybe a software change. Both of which i doubt is out there in the aftermarket. We'd probably be the first to try.
Old Mar 12, 2008 | 12:44 AM
  #48
Zipho's Avatar
hmmm, you going to check that out?
sounds interesting, as that intial hesitation is the one thing I would like to diminish. otherwise I'm happy with her pull in the mid/high ranges.
Old Mar 12, 2008 | 11:45 PM
  #49
Ken1997TL's Avatar
I have tightened the throttle cable, that fixed part of the issue
I'm not interested in messing with the torque converter..
Old Mar 17, 2008 | 03:03 PM
  #50
BelowRadar's Avatar
shift plate
Ken.... I ordered my scuteon cover....... well we'll just say shift plate. All you have to do is undo the clips near the beverage holder to insert... correct ? ? ?
Old Mar 17, 2008 | 04:46 PM
  #51
Ken1997TL's Avatar
Actually I just used a thin piece of metal with a cloth over it to pry off the shift plate, it just snaps off and the new one snaps in. No need to take the console apart!
Old Mar 17, 2008 | 05:03 PM
  #52
BelowRadar's Avatar
I could have sworn that it comes out from underneath. From previous experience when mine came loose where the wood grain ends just before the tray. But ok ... I'll take your word for it. Will let you know when it arrives
Old Mar 17, 2008 | 08:01 PM
  #53
Ken1997TL's Avatar
You're right. My bad. You need to take the black cover around the shifter off first.
Pry it up with a flathead screwdriver (covered with a cloth to prevent scratching the wood)
Old Mar 22, 2008 | 12:34 PM
  #54
BelowRadar's Avatar
shift cover
My Scuteon-thinga-ma-jig came in today..... does add an extra accent to the console
Old Mar 22, 2008 | 12:58 PM
  #55
BelowRadar's Avatar
problem is.... the old ones on their pretty tight....... scared to break the 4 tabs that hold it on
Old Mar 22, 2008 | 03:13 PM
  #56
3.5RLv-tec?'s Avatar
Are you talking about how to turn the shift gate into chrome?If so just push the shift gate to the right side( hard but not too hard lol) and push up...BTW I use auto stripper to remove the color, after 15 mins.. da da chrome baby!!!
Old Mar 22, 2008 | 03:15 PM
  #57
Does anybody hear about the STS stage III universial bolt on turbo?? i just wondering if good for my 96 RL lol... they said you can put the turbo anywhere that including in the trunk or underneath the car.. that's crazy
Old Mar 22, 2008 | 03:31 PM
  #58
BelowRadar's Avatar
I just ordered one from Delray Acura for like 20 bucks. If you scroll down to some of the previous posts in this thread, Ken left a link for it. I just was afraid of how much pressure to use on the plastic in there. It's a little chilly outside here in Md, and I know how cold+plastic = brittle.
Old Mar 22, 2008 | 03:41 PM
  #59
lol yea i know, but i did save 20$
Old Mar 22, 2008 | 08:08 PM
  #60
Ken1997TL's Avatar
Don't add a turbo to a car if you don't know what one is.. just a word of advice
Old Mar 22, 2008 | 09:53 PM
  #61
swift22's Avatar
luvs redheads!
Ken if you or anyone else actually starts doing performance modding hit me up on PM and I would be willing to help.
FYI-Just hooked up Apexi Neo and no a few tricks also.
Old Mar 22, 2008 | 10:49 PM
  #62
Ken1997TL's Avatar
What did you do for the higher compression? I'm curious...
Old Mar 23, 2008 | 01:48 PM
  #63
lol but I want a turbo... going to ask my local performance shop for help
Old Mar 23, 2008 | 07:16 PM
  #64
swift22's Avatar
luvs redheads!
Some people know, some don't. I keep it to myself now but its a custom piston swap.
Old Apr 9, 2008 | 04:26 AM
  #65
classicKA9's Avatar
High End
heres a thought. was thinking if you can mod the head of the RL into an NSX. RL's engine code is a C35A and the nsx sohc is a C32A. I friend of mine said it won't work. but imagine a swap off an NSX?? damn that'll be crazy. One more thing does the NSX and RL share the same brake set-up in the front?
Old Apr 9, 2008 | 09:28 PM
  #66
Ken1997TL's Avatar
They are both called "C" blocks, but they share virtually nothing in common. The oil passages, bolt patterns and everything else are different.
Old Apr 9, 2008 | 10:27 PM
  #67
So does anybody knows what mod going add maybe 30-50 horsepowers to the RL lol. It's hard to find aftermarket part for this car.
Old Apr 9, 2008 | 10:49 PM
  #68
Ken1997TL's Avatar
Port/Polish the heads, change the intake manifold
Old Apr 10, 2008 | 02:37 AM
  #69
supernick37's Avatar
Rampaging RL
quick way= nitrous
right way =$$$$$$$$$$$$
port and polish, deck the head (increase compression) port match the intake manifold, or swap to a Type II mani? (not sure on that one), rework the exhaust, blah blah blah
Old Apr 10, 2008 | 01:01 PM
  #70
supergreen's Avatar
Talking
Do we get to see pics of all this "modding?"
Old Apr 10, 2008 | 09:08 PM
  #71
ok that sound really good lol. Do you know how much they going to charge the port and polish for the head?And how many horsepower does it increase..15 LOL...Change the intake manifold??? can you give me some information like what parts stuff like that...thx
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
