Intake Question for 2002 RL
I want to put an intake system on my '02 RL that'll be both functional and sound a little beefier. I went to a race shop and was told that I couldn't take out the box because I'd get error messages on the instrument panel or something.
So, is there something that can be done so I could at least take the box out and not have problems?
大日本帝国
You won't get error messages, and if you get a CEL, you can just reset the ECU by disconnecting the negative terminal for 30 seconds. Simplest thing to do would be to get a drop-in K&N filter, and remove the resonator at the bottom of the intake. It'll look stock but will have a deeper growl under load, plus the filter is more efficient.
~Cheers~
~Cheers~
大日本帝国
It's basically that jumble of tubes that lead nowhere. Everything below the box where the filter goes is basically for sound tuning. There's more to it than that but I won't get into it here. A 10mm socket is all you need to do this. BTW, had you gone to a real "race shop" they would've known better than to tell you it's going to give you a CEL. I think you went to a "rice shop" instead, hehe.
~Cheers~
~Cheers~
~Cheers~
~Cheers~
~Cheers~
~Cheers~
Received 2,329 Likes
The resonator is under the front bumper. Its basically a chamber that reduces the booming noise that engines make under load.
A CEL is a check engine light.
cycdaniel
12-17-2019 10:58 AM
