HOW to remove the wood trim????
Old Sep 11, 2005 | 12:19 PM
killakill's Avatar
hey i just got a 1999 acura rl n i wanna add a sub but i dont know how to remove the wood trim to get acces to the stock radio can someone plz help me
Old Sep 13, 2005 | 06:20 AM
flyfishindawg's Avatar
Removing trim
You will probably find two screws in one of two places:
1) First you pull up the trim piece that surrounds the shifter, etc. Look to see if there is a bar behind the ashtray with two screws in it. If so, remove these and the trim that you are trying to remove should come up fairly easily from the bottom, or,
2) There are two pieces of carpet-covered plastic that will need to be removed. Each are high and on the inside portion of the footwell on each side of the console area. Once these are removed, there will be a screw on each side of the console (set pretty far in) that you will need to remove. Once these are removed, you should be able to pull the trim out, no problem.
Hope this helps,
FFD
Old Sep 14, 2005 | 09:01 AM
killakill's Avatar
thank u very much
thanks alot helped alot!
Euro4gen
Dec 12, 2015 03:14 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
12vancover
Oct 16, 2015 12:04 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
Hines57
Sep 24, 2015 01:58 PM
