accessory/cigarette lighter
Old Jun 27, 2010 | 09:12 AM
thaillest30's Avatar
Universal Soldier
My cigarette lighter has either blown a fuse or popped a relay, and I cannot locate it. I've looked all around the vehicle to include the fuse box and the one under the hood. any help would be greatly appreciated!!!!
Old Jul 19, 2011 | 03:41 PM
RMCharlie's Avatar
3rd Gear
Cigarette Lighter
I have the same thing, my lighter is not working and it beats me why not. I am not get power to it. I have taken the housing out and checked it. It is fine and the wiring also checks out. I get power from the connector. everything says it should be working, but it does not.
Old Jul 19, 2011 | 06:44 PM
RMCharlie's Avatar
3rd Gear
I got it figured out. there is a fuse, but it is disguised as a black wire. Very sneaky Acura. This is at the base of the lighter housing and it is about an inch long. You can not tell it is broken unless you can feel it with your fingers. I had enough of the wire left to hook it up again, but you may need to get a new lighter.
Old Jul 19, 2011 | 08:56 PM
Universal Soldier
Much appreciated!
Old Aug 10, 2011 | 03:19 PM
RMCharlie's Avatar
3rd Gear
Solution to cigarette lighter
Originally Posted by RMCharlie
I have the same thing, my lighter is not working and it beats me why not. I am not getting power to it. I have taken the housing out and checked it. It is fine and the wiring also checks out. I get power from the connector. everything says it should be working, but it does not.
I got it working. On the base of the lighter housing is a small wire about 1/2 inch long. It is covered with black rubber. This is a fuse, but you cannot tell that it is blown because of the rubber covering it. Once I replaced it the lighter works fine. Mine blew out using my 12v air compressor. I won't do that again.
Old Aug 10, 2011 | 03:45 PM
3.5RLv-tec?'s Avatar
This happen to me too, every time i plug something into the lighter the fuse blew(fuse box engine compartment). So all I need is a new lighter rite?
Old Aug 10, 2011 | 09:18 PM
Universal Soldier
Im glad you solved your dilemma. That cig lighter is such a p.i.a.!! I cant use my GPS nor phone charger due to it blowing out. I guess Ill put that on the to-fix list.
Old Oct 5, 2011 | 07:19 PM
MistahWes06TL's Avatar
I have always had the problem for the one in the center console storage area, and tonight my little cubby hole one blew. worst part is, i needed it the most tonight, my phone was on 5% battery lol. well ill be doing this this week when i get some time i guess.. glad someone found answers, i couldnt find anything on it in my haynes manual.
funkbro2
Nov 17, 2015 10:23 PM
Rob144
Sep 21, 2015 08:18 AM
Sep 14, 2015 10:09 PM
kuzdu
Sep 10, 2015 08:42 PM
